Go to Post Didn't know the details about the battery. In the past it was just a black (grey) box with two terminals...use...recharge...use..recharge. - cbolin [more]
Unread 04-02-2007, 18:13
xxMORT11xx's Avatar
xxMORT11xx xxMORT11xx is offline
FRC #0011
xxMORT11xx will become famous soon enough
RS-545HS Gear and Pressure
Does any one know the gear pitch and pressure angle for the RS-545HS Motor?
Unread 04-02-2007, 18:49
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: RS-545HS Gear and Pressure
I know that it has a 3.2mm shaft, and you can remove the gear with a special gear puller that you can buy for under $20 from Banebots and probably from lots of Radio Control car hobby stores. Then you can intall the gear you need on the motor. The gear should be available from the place that sells the transmission you are planning on using, or from the motor that came installed on that transmission.
Unread 04-02-2007, 22:01
xxMORT11xx's Avatar
FRC #0011
Thanks thatll cover the pitch does anyone have any ideas on the pressure?
Unread 05-02-2007, 00:31
MrForbes's Avatar
AKA: Jim
I think my post above was not very clear, because you seem to not have deduced what I meant....sorry for that!
I meant to take the mystery gear off the 545 mabuchi motor, and throw the gear away in the garbage. Then find a new gear that will fit the 3.2mm shaft, one that you know what the pressure angle and pitch are, and put it on the motor.
Unread 05-02-2007, 16:49
xxMORT11xx's Avatar
FRC #0011
Thanks
KitBox Gear Info - What pressure angle? coreyjon Technical Discussion 2 14-02-2005 22:01
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
Dump valve and pressure gage's tareyton Pneumatics 3 06-02-2003 21:13
Gear Pressure Angle and Pitch. Patrick Wang Technical Discussion 20 13-08-2002 20:33
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
