Help with the SMC SOlenoid
Ok, So we read in the part description that when you charge both sides of the double solenoid it should hold position, however, this does not seem to be workin very well, we are looking over the schematics and the charts are not making sense does anyone know how to wire to up so we can have a forward, reverse, and a hold?
Re: Help with the SMC SOlenoid
From the 2007 Pneumatics Manual:
OK, that is wrong, if that is the situation, then how are we supposed to stop a solenoid in Mid stroke which is what we need to accomplish because we are using a scissor lift...
The following thread should give you some ideas: http://www.chiefdelphi.com/forums/sh...ad.php?t=40040
The double solenoid that was shipped with the kit does not hold position. It either goes to one side or the other and when it does, the other side is exhausted to the atmostphere. You can make it hold by hooking up another solenoid to the exhaust and turning it on or off to make it hold. Another solution is to buy a valve that is "center off". It will hold position. See the other threads mentioned.
Brian |
| Help with double solenoid | almsfan21 | Pneumatics | 2 | 30-01-2007 19:57 |
| SMC Double Solenoid Screw | Sscamatt | Pneumatics | 0 | 12-02-2005 01:24 |
| Anyone willing to trade (something they need) for the SMC double solenoid? | Jeremy | Kit & Additional Hardware | 0 | 27-01-2004 20:14 |
| SMC Double Solenoid Valve Assembly | Dave Kempskie | Pneumatics | 0 | 29-01-2003 13:34 |
| Single Solenoid Valve SMC | Chubtoad | Technical Discussion | 3 | 20-01-2002 15:16 |
