Go to Post (You know you're overdosed on FIRST) when watching regional web-casts takes precedent over Saturday morning cartoons. - Hawiian Cadder [more]
Unread 05-02-2007, 22:28
zim2411's Avatar
zim2411 zim2411 is offline
AKA: Peter Harris
FRC #1727 (Rex 1727)
zim2411 is a jewel in the roughzim2411 is a jewel in the roughzim2411 is a jewel in the rough
Multiple actuators per solenoid?
I combed through the manuals on pneumatics, and I couldn't find any mention of this, but I probably just missed it.
We need to have 4 linear actuators go off at once, in addition to other pneumatics parts on our robot. We only have 4 double solenoids available (the SMC ones) so my question is, can we hook up a T fitting after the solenoid to allow multiple actuators going through one solenoid? I know we can hook multiple solenoids up to a spike, so that isn't the problem.
Unread 05-02-2007, 23:13
Electrical Engineer
Rookie Year: 1995
Re: Multiple actuators per solenoid?
Yes, you can connect multiple Bimba cylinders to a single solenoid via T connections. However, you mentioned "linear actuators" which is the industry buzzword for specialized devices which are not allowed on a 2007 FIRST robot. The only "actuators" you are allowed are the Bimba cylinders listed on the last page of the 2007 Pneumatics Manual.
Mike Betts
As easy as 355/113...
Unread 06-02-2007, 10:18
zim2411's Avatar
AKA: Peter Harris
Ah sorry, I mean the Bimba cylinders. Thanks for the info!
Unread 06-02-2007, 10:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Just remember that you are dividing the air between the cylinders hooked up to the same solenoid kind of like dividing the current in a parallel circuit. It’s also a good idea to use the flow control fittings so you can balance the speed of the cylinders.
You can also purchase more solenoids if you need to.
actuators Transformers Pneumatics 1 27-01-2007 02:48
Multiple cylinders on a solenoid robogeek753 Pneumatics 5 12-01-2007 00:06
actuators KillerCows456 Technical Discussion 1 18-01-2006 17:04
multiple cyclinders from one double solenoid Ed Crammond Pneumatics 1 07-02-2003 18:49
Rotating Actuators? turbidum Rules/Strategy 3 12-02-2002 02:47
