Go to Post Be thankful for what you have, not frustrated with it because it doesn't exactly suit your needs. - sanddrag [more]
Unread 07-02-2007, 23:56
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Rotation Sensors
Hi,
We're currently trying to get our potentiometers working and programmed, but if they don't work we'd like to have a back-up plan. Can any team recommend rotation sensors that they have used in the past?
Unread 08-02-2007, 00:13
Jared Russell's Avatar
Taking a year (mostly) off
Re: Rotation Sensors
Potentiometers are nice and easy for actuator positioning if you can (1) mount them to the final output shaft and (2) the output shaft doesn't rotate 360 degrees continuously.
If you can't do that, use an optical encoder. www.kevin.org/frc has an encoder FAQ.
Unread 08-02-2007, 13:10
steve d steve d is offline
FRC #1277
steve d is an unknown quantity at this point
This is what we're using:
http://www.bourns.com/pdfs/6539.pdf
It's a pot that keeps turning. It's called a Follow-up pot. The resistance goes back to zero after a full turn, but there are no stops so it can turn all the way around. We have it going to analog in 1 and use the AD converter to read it.
Unread 08-02-2007, 13:38
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Originally Posted by brennerator View Post
Hi,
Pots are actually the easy and reliable technique.
Shaft encoders are the alternative, but are more troublesome to specify and code.
Unread 08-02-2007, 14:20
cyclops8807 cyclops8807 is offline
FRC #1625 (Winnovation)
cyclops8807 is on a distinguished road
Send a message via AIM to cyclops8807
Team 1625 is using the US Digital MA2. It works well because it is an aboslute analog encoder that is the equivalent to a 10-bit digital. Plugs right into the RC Analog in, and gives 1024 different steps for one rotation so it has enough resolution for almost anyone. Its also pretty cheap too.
Here is the link. http://www.usdigital.com/products/ma2/
Do Not Eat.
Unread 09-02-2007, 01:15
Thanks for all of your responses. We're going to try and use the follow up pot.
Unread 09-02-2007, 09:18
kaszeta's Avatar
Those look nice. I may have to try one of those next season.
Rotation Systems Goaliexam Technical Discussion 9 06-06-2006 17:56
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
Yellow Rotation Sensors ? de_ Electrical 6 26-04-2005 15:40
Servo Rotation indieFan Motors 6 13-11-2004 13:41
Interrupts and rotation sensors kor Programming 3 12-02-2004 11:05
