Go to Post Since you have to undo all the connections anyway in order to swap them, you might as well take advantage of the opportunity to do some simple and straightforward troubleshooting. - Alan Anderson [more]
Unread 10-02-2007, 01:40
brennerator brennerator is offline
brennerator is an unknown quantity at this point
Help! Analog Inputs!!
Were using a potentiometer and I have no idea how to read the potentiometer value!
PLease help
Unread 10-02-2007, 02:00
kitscuzz's Avatar
kitscuzz kitscuzz is offline
Not alotta posts
AKA: Kit
FRC #1389 (Worst Case Scenario)
kitscuzz will become famous soon enough
Re: Help! Analog Inputs!!
Simply plug your POT into a analog port
Then use Get_Analog_Value(rc_ana_in0*)
Where * is the number port you placed the POT.
It will return a value between 0 and 1024, depending on how far it has been turned.
Unread 10-02-2007, 02:13
So i just printf("Pot %d\r", Get_Analog_Value(rc_ana_in0*)); to display it?
Unread 10-02-2007, 02:31
JimHull's Avatar
JimHull JimHull is offline
FRC #1891
JimHull is an unknown quantity at this point
Yes that should do it.
Unread 10-02-2007, 08:41
ScottWalls ScottWalls is offline
FRC #0245 (AdamBots)
ScottWalls will become famous soon enoughScottWalls will become famous soon enough
Well, to clarify, you would replace * with the number of the analog input you put the potentiometer into. For example, if you plugged the potentiometer into analog input 1, you would put
printf("Pot %d\r", Get_Analog_Value(rc_ana_in01));
But you may have already known that.
Unread 10-02-2007, 10:56
Shinigami2057 Shinigami2057 is offline
Slackware Is Your New God (Mentor)
AKA: Harry Bock
FRC #1350 (Rambots)
Shinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really niceShinigami2057 is just really nice
It doesn't really matter in this case, but when using an unsigned value, like analog inputs, you should use %u and not %d (the ADC conversion gives you a 10-bit value, 0-1023, so it should never come up as negative, but it's good to know in case you need a full 16-bit unsigned int).
Just make sure that the pot is properly connected (red + black leads to the outer leads on the pot, white to the wiper/middle lead) and you should have no problems. Our arm potentiometer got disconnected during testing and its value started creeping by 1 every few seconds, it was really weird. O_o
One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs.
Unread 10-02-2007, 12:47
Eclipse's Avatar
Eclipse Eclipse is offline
AKA: Sensei Hanzo
FRC #1250 (Gatro-Bots)
Eclipse is an unknown quantity at this point
Also, make sure you've included ifiutilities.h in whatever file you're using Get_Analog_Value() or else it won't work. o_o
xXx.S3nS31-h4nz0.xXx
Unread 11-02-2007, 15:48
Bomberofdoom's Avatar
Bomberofdoom Bomberofdoom is offline
Biggest FIRST addict in Israel
AKA: Nir Levanon
FRC #2230 (Zcharia's Angels)
Bomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond reputeBomberofdoom has a reputation beyond repute
Send a message via MSN to Bomberofdoom
Yep, Get_Analog_Value('the analog input number').
Analog Inputs bush Programming 5 13-03-2006 17:49
Analog Inputs prob. Bharat Nain Programming 2 07-02-2004 20:48
Failing analog inputs? Phasmatis568 Control System 5 22-01-2004 13:28
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
Analog Inputs 316_programer Technical Discussion 2 05-02-2002 05:53
