Go to Post I think that everyone should just take a step back and look at the whole picture, FIRST is a family, not an organization full of regions, we all try to help each other, not 'cause it benefits us, but because it's graciously proffesional. - Mike Schroeder [more]
Unread 10-02-2007, 22:58
the_innovator the_innovator is offline
Co-head of Programming
FRC #1241 (Theory 6)
the_innovator is an unknown quantity at this point
_stack error
I'm trying to compile a modified version of Kevin's serial_ports.zip but get the following error:
Error - could not find definition of symbol '_stack' in file 'C:\10byte frc_serial_ports\ifi_startup.o'.
The only extra files I've included are eeprom.c, eeprom.h and a custom header & source file.
This problem's been bugging me for 2 hrs now. Any suggestions?
Unread 10-02-2007, 23:08
dpick1055's Avatar
dpick1055 dpick1055 is offline
David Pick
FRC #1739 (Chicago Knights)
dpick1055 is on a distinguished road
Send a message via AIM to dpick1055
Re: _stack error
is _stack a variable your trying to use?
Always remember to take your powered wheels off the ground when first testing code. Otherwise you'll end up with holes in the wall like us
180:Error: syntax error help! seanl Programming 8 04-02-2007 11:31
C18 v2.4 -- Syntax error where there is no syntax error Joel J Programming 7 12-01-2007 17:27
stupid Array error: Error [1300] stack frame too l Validius Programming 7 27-01-2006 10:53
ERROR amateurrobotguy Programming 22 28-02-2005 17:28
