Need help making water
can someone help me out with making some water , all i need to do to finish our animation is make a flowing stream of water, but i have no idea how to.... i really would apprecdiate some help!!
Re: Need help making water
For rivers, streams, creeks, etc. you can make a plane, give it a noise displacement map, and animate the offset of the map to make it "flow."
For faucets, pouring water, etc. you can try Blobmesh, but it's tricky. |
A stream of water can be made with particle flow/spray particles (if you don't know how to use particle flow)
I think you are a bit late, because you will discover that it's a lot of render time for raytraced particles... But if you want to get a good water... Water is basically transparent, 75% refractive and 50% reflexive (we're talking about pure water)... These are the configurations you should use (well, I do use it =p) with your raytraced material. Remember that a reflexive/refractive material need an environment to reflect/refract, and if you haven't got one, you should fill the "environment" slot of your material with an HDRI map. Then to make a flow, you need to set up a particle emitter: super spray may work, but if you want to get more flexibility, use particle flow. I recommend you to look for a tutorial with google, because I need images to get further explanation. Good luck with it =P |
You didn't say anything about what kind of water you want. There are so many different ways to make water.
| Help - Making the autonomous mode | razer | Programming | 5 | 31-01-2007 16:25 |
| Need Help Making Part from Spec | Goaliexam | Inventor | 10 | 26-07-2006 11:34 |
| HELP!!!!!! LABVIEW IS MAKING ME MAD!!!! | cdennisxlx2 | LabView and Data Acquisition | 2 | 21-03-2006 21:50 |
| Making a Dongle - Pin 1 help | DanL | Electrical | 6 | 05-03-2003 16:58 |
| I need help w/ making an Invitational | Matt Attallah | General Forum | 6 | 14-05-2002 19:48 |
