Camera Video out
Hi Everybody,
I was just looking at the diagram of the camera and all of its outputs (http://kevin.org/frc/camera/first_cm...revision_a.jpg) and i saw the Video out header in the top left corner. Can you hook this up to an RCA cable and hook it up into a TV? If not, what can it be used for? Thanks |
Re: Camera Video out
Yes, you can.
Does anyone know if the video out header shows the full field of view that the camera sees?
I've a number of about a 60* field of view floating around, and the camera seems to have a roughly 2:1 aspect ratio, but the video we get on our TV isn't black barred or black boxed or whatever it's called (like when you watch a DVD on a regular TV). |
So the video is the whole image that the sensor picks up, upsampled to 640x480?
Cool, thanks for all the response, i'll be sure to try this out tonight!
#7
I'm not sure that 'upsampled to 640x480' is as correct as "converted to NTSC". Depending what camera module you have, you either get an NTSC signal or a PAL signal, and since they are strictly analog they don't really have pixels.
#8
It's a close approximation to NTSC or PAL, anyway. And its modulation is digital enough to make talking about pixels reasonable.
#9
And after all this, the answer to the question itself is what?
Robinson |
#10
Note that the output from that connector does not include color. It's a simple black & white video signal.
| Out of the Box Camera Code | russell | Programming | 9 | 21-10-2009 05:28 |
| Getting the Camera out of Idle | Eclipse | Programming | 2 | 13-02-2007 04:06 |
| Camera Is Spazzing Out! | BrittanyV | Programming | 15 | 04-02-2006 13:39 |
| Camera Freaking Out | adodge | Programming | 2 | 26-01-2006 21:13 |
| Using camera PWM out | Cuog | Programming | 2 | 28-11-2005 14:17 |
