Go to Post and don't overestimate the ability of an unskilled fool with exotic tools! - MissInformation [more]
Unread 11-02-2007, 17:43
GeorgeC GeorgeC is offline
FRC #1934
GeorgeC is an unknown quantity at this point
Limit Switch for PCM
Can anyone help with an easyC mindbender?
I've used all of my available spike relay controllers and programming limit switches using them in easyC was straightforward.
Now i need to control a motor using PWM and a limit switch but I can't think of how to code in a limit switch.
What I want to do is program something like if limit==0 then PWM1 ==<127. However in easyC I can't see the actual variable to assign my values to.
I guess that PWM outputs are to program drive motors which don't usually need limit switches.
Anyone got any ideas?
Unread 11-02-2007, 23:02
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Re: Limit Switch for PCM
Create your own variable to hold the value of the limit switch (connected to a Digital Input, of course).
Then you can do something like:
switchstate = DigitalInput(10); // read DI 10 limit switch
if (switchstate == 1)
pwm = 127;
else
pwm = something else;
PWMOutput(2, pwm); // output pwm value to PWM2
You are correct, the EasyC functions provided for PWM output do not include support for limit switches.
Unread 12-02-2007, 14:08
FRC #1934
Thanks That's got me on the right track.
Nice to hear from someone who talks in EasyC
Regards
GeorgeC
Unread 12-02-2007, 15:06
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Try this
if ( GetDigitalInput ( 1 ) && Input > 127 )
            Input = 127 ;
      else if ( GetDigitalInput ( 2 ) && Input < 127 )
            Input = 127 ;
If you are using an OI to PWM Block
Then delete it and add this.
Input = GetOIAInput ( 1 , 1 ) ;
            Input = 127 ;
            Input = 127 ;
      SetPWM ( 1 , Input ) ;
Unread 16-02-2007, 13:21
FRC #1934
Many thanks for taking the time to post the code
GeorgeC
Limit Switch Basics JWSnedden Programming 6 30-11-2006 19:48
Limit switch in easy c? chadbarbe Programming 6 02-02-2006 09:51
How do you wire a limit switch? JMH Electrical 1 16-02-2005 17:44
gyro/accelecometer/limit switch help needed Anton Programming 4 04-02-2005 16:39
sample limit switch code??? tml240 Programming 5 17-02-2004 17:13
