Switching to/from autonomous mode
HI EVeRYBODY!!!
![]() ANSWER ME ON TWO QUESTIONS: 1)HOW I AM CHANGING TO AUTONOMOUS MODE WITHOUT CONFIGURING THE COMPETITON PORT AND ALSO WITHOUT USING A TETHER. 2)WHAT IS THIS ERROR: "main.c' name exceeds file format maximum of 62 characters." TNX FOR YOUR HELP! ![]() |
Re: HELP ME PLZ
1.) Did you set your team number in the OI?
2.) Your files are nested too deeply try moving them to c:\folder name |
Re: HELP ME PLZ
1- well you're gonna wanna make an "Autonomous Switch" that allows you to switch between autonomous mode and R/C mode. I believe this plugs into the competition port. It's pretty easy you can buy all the stuff at radioshack. 2-Dunno. I'm not a programmer. |
Re: HELP ME PLZ
For example, you can have something like Code:
if(p1_sw_top == 1)
Re: HELP ME PLZ
im not in programing but the there is a switch that gets plugged into the OI called a dongle that allows you to toggle autonomus mode on or off.
Re: HELP ME PLZ
1. Here is the schematic for the dongle. http://www.ifirobotics.com/docs/comp...guide-reva.pdf
2. The maximum length for the file names are 62 chars. Move your code to a short path(ie. C:\robots\2007\). |
#7
Re: HELP ME PLZ
| Autonomous Switching | Nicole_Ypes | VEX | 11 | 17-03-2007 08:09 |
| Autonomous and user controlled mode switching | sparrowkc | Electrical | 3 | 15-01-2007 13:15 |
| Question about switching autonomous modes | DemonYawgmoth | Programming | 2 | 23-03-2005 17:02 |
| Receiving info from OI to select autonomous mode | Mr. Lim | Programming | 21 | 17-02-2005 00:56 |
| Switching the break mode | archiver | 2000 | 2 | 23-06-2002 23:28 |
