Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 12-02-2007, 14:49
WGRAY WGRAY is offline
FRC #2027
WGRAY is an unknown quantity at this point
Aux 1 & 2
What function blocks, and what steps do I take to get the aux 1 and aux 2 button on my joysticks to signal my pwm outputs?
Unread 12-02-2007, 14:59
Imajie Imajie is offline
AKA: James Letendre
FRC #0195 (Cyber Knights)
Team Role: Electrical
Imajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud ofImajie has much to be proud of
Send a message via AIM to Imajie
Re: Aux 1 & 2
Assuming you're using EasyC you want to add something like this to your Operator_Control function
if(GetOIDInput([joystick port], [button]) == 1){
    //Button pressed so drive motor
    SetPWM([port], [value]);
else{
    //Button not pressed stop motor
    SetPWM([port], 127);
I believe that 3 and 4 are the numbers for the aux1 and 2 but I could be wrong.
2007 UTC Champions Thanks 1124 and 558
2007 UTC GM Industrial Design Award
2006 Newton Divisional Winners
2006 Championship finalists
(Thanks 25 and 968 for picking us!)
2006 National Innovation in Control
OI Aux Fault light red Vashts6583 Control System 1 25-01-2006 23:10
pic: Teams 1114, 1503 & 1680; NiagaraFIRST.org Karthik Robot Showcase 15 25-02-2005 13:27
pic: The Bobcats 2001 & 2003 & Admirers CD47-Bot Robot Showcase 19 28-02-2004 12:36
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
More than 2 aux switches in 1 port f22flyboy Programming 2 01-11-2002 14:44
