Go to Post everybody wants a piece of success! - Taylor [more]
Unread 12-02-2007, 19:26
Kevin Thorp's Avatar
Kevin Thorp Kevin Thorp is offline
AKA: Kevin Thorp
FRC #3489 (Category 5)
Kevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond reputeKevin Thorp has a reputation beyond repute
Problems Scaling a Biped
One of our animation teammates accidentially created a character (a teenage girl) 5 1/2 meters tall instead of 5 1/2 feet. She has a biped skeleton w/physique.
When we tried scaling her down it down it deformed her skin so horribly that she can only be used in a bizzarre horror movie.
Is there any way to resize her without having to delete & reapply physique? It'll take a few hours to adjust physique after we apply it.
Unread 12-02-2007, 19:40
Mazin Mazin is offline
FRC #1720
Mazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to allMazin is a name known to all
Send a message via AIM to Mazin
Re: Problems Scaling a Biped
I don't use Biped much, but you could maybe try turning off Physique (not deleting), and then scaling the person mesh, and then adjusting the Biped's property to be the right height (not scaling the biped).
Or, how about you scale everything else by three instead? (or does it involve other bipeds?)
Unread 12-02-2007, 20:17
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
I had the same probliem, it was a pain to fix. If you can, before you add it to your scene scale it (take off the Physique for a moment) The way I ended up fixing it for me was to scale the entire scene up
Unread 12-02-2007, 20:23
FRC #0701 (RoboVikes)
Why can't you just scale the biped and the mesh together? then re apply physique?
Team 701
Unread 12-02-2007, 20:45
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
Wait, did you scale her down as in use scale? Or did you just change her height?
To change the settings of a biped that has already been made:
Select one of the biped's bones, click the motion tab on the command panel, enable figure mode (looks like a stick figure), open the structure roll out, and you can change the height. Hope this helps.
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Unread 12-02-2007, 23:03
AKA: Kevin Thorp
Thanks for all the suggestions.
Our scene has another biped - to the correct scale. So we don't want to resize the static objects.
I tried changing the height of the biped skeleton. That mostly worked but the skin has some stray vertices. I'll either have to clean them up or re-apply Physique and fiddle with the envelopes again.
pic: VEX biped s_forbes Extra Discussion 8 04-10-2006 21:39
Biped system robcataus 3D Animation and Competition 2 07-02-2005 08:47
Robo-One Biped Robots Nathan Pell General Forum 6 29-06-2004 14:32
LEGO Biped Project rlowerr_1 Robot Showcase 23 07-09-2003 14:21
Skinning a Biped BOMBer84 3D Animation and Competition 2 20-02-2002 22:43
