Go to Post Just because its a robotics competition does not mean everybody is a big dork. - Taxi Quinn [more]
Unread 13-02-2007, 17:04
Transformers Transformers is offline
FRC #2260 (Transformers)
Transformers is an unknown quantity at this point
Magnetic Reed Switches...
I had a quick question about exactly how to wire these. Do we just wire them directly in line with the solenoid or is there another specific wiring diagram because i am not seeing it anywhere? Thanks for the help.
Yes, Spanky
Unread 13-02-2007, 17:40
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Magnetic Reed Switches...
Do not wire it in-line with the solenoid! You should wire it to a digital I/O pin on the RC, in the same configuration that you'd use for a limit switch.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 13-02-2007, 17:55
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Wiring it in line is no good.
On a semi-interesting side note, though... Instead of wiring the 120 psi pressure gauge as a digital in, you can just put it in-line with the compressor on any non-FIRST bot. This is Illegal in FIRST. It's nice to be able to do this when you have limited access to programming on old Basic RCs, but is kinda useless for newer brains...
Unread 16-02-2007, 19:39
Vashts6583's Avatar
Vashts6583 Vashts6583 is offline
The sleepless
AKA: Rob Metzger
FRC #0007 (Team 007)
Vashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to allVashts6583 is a name known to all
Send a message via ICQ to Vashts6583 Send a message via AIM to Vashts6583 Send a message via MSN to Vashts6583 Send a message via Yahoo to Vashts6583
ok, so does that mean we wire it active high? black to ground, red to hot?
2005: Software Assistant
2006: Software Head
2007: President/Driver/Software Head/Temporary Safety Captain
//2005: Chesapeake Regional - Finalist
Life is what you do outside of FIRST. No wonder it's so short.
Unread 16-02-2007, 20:42
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
I'm not totally sure what your terminology means, but you should wire the red on the switch to the white on a PWM cable, and the black to the black.
_
Unread 17-02-2007, 01:12
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Just like any other switch, between the signal and ground pins. Since it's a switch, there's no polarity to the device.
Magnets and reed switches (what's an AT?) jgannon Electrical 3 10-01-2007 11:17
Magnetic Reed Switches and cylinder boom positions???? cdennisxlx2 Pneumatics 7 11-07-2006 21:17
Magnetic Reed Switches (need help) cdennisxlx2 Pneumatics 1 03-02-2006 06:47
I need help with the reed switches!!!!!!! archiver 2001 2 24-06-2002 00:40
Reed switches archiver 2000 4 23-06-2002 22:08
