Encoder Counting Problems
In order to keep track of the height of our manipulator, my team is using a BaneBots 36mm Gearbox Mount encoder attached to their 64:1, 36mm Planetary Gearmotor, RS-540 Motor. As we move the manipulator up, the encoder starts to count up, but then quickly goes down. Moving the manipulator down makes the encoder count down more slowly.
I have tried the encoder with two sets of code - the interrupts from the Quadratuer Encoders white paper and Kevin's encoder code. In both cases, I am having the same problem. I am getting the encoder values by printing out the number every 26 loops. Does anyone know what might be wrong with the encoder? |
Re: Encoder Counting Problems
did you calibrate the encoder per the directions?
| Problems with Encoder Counting | bjimster1 | Programming | 19 | 07-03-2007 09:59 |
| Encoder Problems | bjimster1 | Programming | 2 | 10-02-2007 08:04 |
| Encoder counting randomly off by x4 factor | jgeorge | Programming | 5 | 02-02-2006 21:17 |
| Problems counting encoder pulses | bludstayne | Programming | 7 | 02-02-2004 23:07 |
