Go to Post Evolution is innovation. - Chris is me [more]
Unread 14-02-2007, 17:17
Shomron1690 Shomron1690 is offline
FRC #1690
Shomron1690 is an unknown quantity at this point
help!!!
I need you to please tell me of the following, which of them is connected to a VICTOR and which of them is connected to a SPIKE?
1) globe motor
2) mabuchi motor
3) gearmotor
Unread 14-02-2007, 17:21
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Re: help!!!
1) globe motor
2) mabuchi motor
3) gearmotor
For those motors, I don't believe it matters... If you just want a foreward reverse brake, then use the SPIKE, if you want speed control or need more than 20AMPs of power, then use a VICTOR. Also, what is this gearmotor that you speak of?
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 14-02-2007, 17:28
Chuck Glick Chuck Glick is offline
Gone Fishin'
Chuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond reputeChuck Glick has a reputation beyond repute
Send a message via AIM to Chuck Glick
Re: help!!!
Globes must be on a VICTOR. We had thought you could run it on a spike, however in the manual it states that it needs to be on a VICTOR. The Globe however, does not need a 40 amp circuit and is allowed to run off a 30 amp breaker from the fuse panel. A good place to check these are in the Tips and Good Practices Page and 2007 Power Distribution page on USFirst.
The Mabuchi can be either of the two. If it's a low torque situation and the motor won't draw much current then use a spike, but if your using it in a high torque situation like in a drive or an arm, then I suggest using a Victor on a 30 amp circuit
what gearmotor do you refer to? Is it the new Keyang Window Motor?
Unread 15-02-2007, 08:23
Re: help!!!
<R92> CIM motors and Fisher-Price motors must be connected to speed controllers. They can not be connected to relay modules.
If the gearmotor you are speaking of is the Banebots with attached transmission, you might be happier with that connected to a speed controller.
section 'InterruptVectorLow' type is non-overlay (was: HELP HELP HELP!!!!!) naor52 Programming 14 24-02-2007 01:19
Help: How do we get a teacher to help? (was: Help) ChaosAlchimey General Forum 13 21-01-2007 11:57
