Go to Post Where we are is only of modest importance. And where we are going is what is really important. - ebarker [more]
Thread Tools Rating: Thread Rating: 15 votes, 5.00 average. Display Modes
Unread 14-02-2007, 21:19
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
6061 Vs 6063
Does any one know any significant differences between 6061 aluminum and 6063 aluminum. I have done the research and am unable to find a significant difference, can any help me out.
"freedom is voluntary self control” Mahatma Gandhi
Unread 14-02-2007, 21:28
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: 6061 Vs 6063
Modulus, as with most aluminum alloys, is approximately the same. However, quoting Mcmaster, 6061 T6 has approximately 4 times higher yield strength- ~40,000 psi vs 16,000 psi for 6063. So depending on the application, a switch may or may not make a difference. If you need stiffness, it won't really make a difference. If it's yield you're after, such as in a threaded rod, pick the 6061.
-Sir Francis Bacon
-Albert Einstein
Unread 14-02-2007, 22:04
Christian Christian is offline
FRC #0408 (RoboTicks)
Christian will become famous soon enoughChristian will become famous soon enough
Send a message via AIM to Christian
Re: 6061 Vs 6063
6061 is also easier to machine from my understanding. It doesn't "mush" up as one of our mentors said.
President/Programming/Mechanical/Electrical/Animation/Website
robots and cake are all you need, everything else like oxygen are considered bonuses.
Unread 14-02-2007, 22:16
redbarron's Avatar
redbarron redbarron is offline
Mike Barron
AKA: Mike
FRC #1270 (Red Dragons)
redbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to beholdredbarron is a splendid one to behold
Re: 6061 Vs 6063
6061 is both stronger and easier to machine because it wont clog the endmill or whatever you are using as easily as 6063 we always use 6061.
The Red Dragons
2005 Buckeye Regional Woodie Flowers Regional Award
2005 Florida Regional Finalist Along with 1251 and 845
2006 Palmetto Regional Engineering Inspiration Award
2007 Florida Regional Judges Award and Regional Winners Along With 1251 and 86
2007 Curie Division Winner with 330 and 910
2008 Florida Regional Team Spirit Award Winners
Unread 14-02-2007, 23:28
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: 6061 Vs 6063
6061-T6 yield is about 39 ksi, versus 31 ksi for 6063-T6. So those McMaster numbers are comparing apples to orange popsicles.
As far as machinability, I don't think the difference is incredibly large. However, 6063 is mostly common for more complex extruded shapes anyways, so you're less likely to be doing large amounts of machining on it in the first place.
Unread 14-02-2007, 23:41
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Thumbs up Re: 6061 Vs 6063
There is some confusion here about the two alloys. Hopefully this will benefit others as well.
"6063" and "6061" are not sufficient descriptions of the materials in question. To know the specific differences, you need to know the specific heat treatment/tempering process of the alloy.
If you compare 6063-T6 and 6061-T6 you will find that their properties are similar with 6063 having a slightly lesser Ultimate Tensile and Yield Strengths. However, if you look at mcmaster, I can only assume they are selling a 6063-T4 and 6061-T6. If you compare them, then yes, 6063 has a considerably lesser ultimate tensile and yield strength. However, for 6063 the % elongation almost doubles, from 12% to 22%.
The machnining differences have everything to do with the heat treatment as well. The T6 alloy will probably machine better than the softer T4.
Edit: Seems that kevin posted part of what I was getting at before I was finished writing. I will leave it as is with a little extra explanation.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 14-02-2007, 23:46
bjimster1's Avatar
bjimster1 bjimster1 is offline
AKA: Jimmy Bourne
FRC #1029 (Wolvcats)
bjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nicebjimster1 is just really nice
Send a message via AIM to bjimster1
Re: 6061 Vs 6063
this pretty pretty much copy and pasted from a Mcmasters data sheet but whatever, the information is all there.
http://en.wikipedia.org/wiki/6063_aluminum
http://en.wikipedia.org/wiki/6061_aluminum
-2006 UCF Quarterfinalists w/ 1345 & 21
-2005 Peachtree Quarterfinalists w/ 1180 & 462
-2005 UCF Quarterfinalists w/ 1694 & 348
CMU '11
Unread 15-02-2007, 02:27
Andy A. Andy A. is offline
Getting old
FRC #0095
Re: 6061 Vs 6063
An exclent source for materials data is www.matweb.com. They offer data on a wide range of materials, and information on different alloys, heat treatments and even specific dimensions of samples.
The relevant pages for the two alloys, both with a T6 treatment.
6063-T6
6061-T6
Of course, its all refrence data, and they keep a disclaimer against using that data for design. Ideally, you would do your own testing with samples of the material as it comes from the supplier. For FIRST purposes, its fine to use handbook data like this.
Testing methods vary from one source to another. The important thing is to pick a reputable source and stick to it. I think there are a couple 'machinist handbooks' out there that would probably have this kinda of data.
Unread 16-02-2007, 19:44
Generator of Entropy
FRC #2973 (The Mad Rockers)
Re: 6061 Vs 6063
I need to throw in my warning here, as I do in every post about 6000 series aluminum. If you weld it, the yield strength goes from about 39 ksi to about 11 ksi in the heat affected zone (usually within about 1 inch of the weld).
