Go to Post Equally possible is that we're just providing some lunch-break entertainment for the people in the GDC. - wasayanwer97 [more]
Go Back   Chief Delphi > Other > VEX
Unread 16-02-2007, 09:44
spsteam1512 spsteam1512 is offline
FRC #1512
spsteam1512 is an unknown quantity at this point
Vex Controller Issues
WE currently have two Vex controllers that have problems that we do not know how to fix.
Depending on their moods, we are able to download programs onto them sometimes. The programs never actually work/make the robots do what we have programmed them to do. They just sit there.
Othertimes we just have lights flashing and other random things.
Does anyone have any ideas as to what has happened to our Vex controllers!??
We would greatly appreciate the help.
Sincerely,
Team 1512
Unread 16-02-2007, 11:30
Re: Vex Controller Issues
Are you able to download fresh Master code as well?
Unread 16-02-2007, 13:32
Electrical Engineer
Rookie Year: 1995
I will add an obvious comment to Mark's: Is your battery fully charged?
Mike Betts
As easy as 355/113...
Unread 16-02-2007, 16:44
Jared W's Avatar
Jared W Jared W is offline
FTC #3228 (S.P.A.M. FRC #180)
Jared W is just really niceJared W is just really niceJared W is just really niceJared W is just really niceJared W is just really nice
Send a message via AIM to Jared W
are you sure your programming the brain right?
Are you making sure to put in a while loop?
Unread 18-02-2007, 01:39
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
After you download the programs (that don't work), are you able to download the default code (that allows use of the remote control, like out-of-the-box factory condition)? Are those 2 controllers completely unusable now?
Unread 19-02-2007, 15:34
rswsmay's Avatar
rswsmay rswsmay is offline
AKA: Robert
FRC #1177 (Mecha-Jags)
rswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the roughrswsmay is a jewel in the rough
All the above questions/suggestions are valid ones. Since this is happening to two of your controllers I am more likely to ask the questions:
1. Is your battery fully charged?
2. Do you have a while loop in your program?
3. If using EasyC, do are you using version 2.8.x.x?
4. Are you using version 7 of the master code?
5. Do you have some autonomous code written? If yes and us used EasyC, use a jumper in interrupt 7 to disable your autonomous code and see if the operator portion works properly.
6. If all else fails, reload the default code or the online code and check the response of all the motor outputs.
Knowledge is only strength.... Knowledge and Wisdom, thats true power.
Unread 19-02-2007, 16:56
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
You can also try the online window which will let you move motors without any programming.
VEX radio controller Greg Needel FIRST Tech Challenge 3 06-05-2007 15:09
First controller out of VEX kiettyyyy Electrical 0 05-11-2006 23:16
IR on the Vex controller? jgarbers FIRST Tech Challenge 0 18-04-2006 14:07
Programming VEX Controller HRobotics Programming 4 21-03-2006 23:25
Drill Motor/Speed Controller/Who Knows What Issues GMitchell Motors 12 28-01-2003 17:11
