help in assembly
i would like to know how can i export dimensions to the idw from parts that are assembled in the assembly doc
Re: help in assembly
You should be able to just put dimensions in the .idw from the assembly. Change to your drawing annotations panel and use the general dimension tool. I could help you better if you were more specific.
| Assembly code in C? | red_alert_13 | Programming | 3 | 21-07-2005 15:01 |
| Assembly? | Astronouth7303 | Programming | 2 | 12-08-2004 11:30 |
| Importing assembly into an assembly... | James Green | Inventor | 8 | 22-01-2004 22:17 |
| Assembly Code | Venkatesh | Programming | 1 | 18-11-2003 17:39 |
| Assembly?!? | archiver | 2000 | 2 | 23-06-2002 22:05 |
