would this work?!?
Would this work or burn something out?
Using EasyC: I have the same setup on both sides of the robot; a pump that heads out/in to lower a ramp on either side (so its actually 2 pumps, 1 on each side of robot) Could I use the same button to lower each and raise each by doing the following OIToRelay (3,1,2,1) //jostick on port 3 trigger button forward to relay 2 OIToRelay (3,2,2,2) //joystick on port 3 thumb button reverse to relay 2 OIToRelay (3,1,3,1) //jostick on port 3 trigger button forward to relay 3 OIToRelay (3,2,3,2) //joystick on port 3 thumb button reverse to relay 3 Would it cause problems trying to use the same input to control relay outputs??? |
Re: would this work?!?
I'm not a programmer, but it looks to be fine.
| Would the following work!?! | Asheron | Programming | 2 | 19-02-2007 11:27 |
| Designs that would never work... | Cyberguy34000 | Technical Discussion | 60 | 09-01-2007 20:56 |
| Would this mesh be legal? | wun | Rules/Strategy | 3 | 21-02-2004 09:28 |
| Would this balance? | MattK | General Forum | 9 | 16-04-2003 20:11 |
| I found this funny(who would do this?) | E. The Kidd | Chit-Chat | 29 | 16-08-2002 16:03 |
