Go to Post You can take my blocker... but you can never take my cheesecake! - Andrew Schreiber [more]
Unread 18-02-2007, 14:41
Jake M Jake M is offline
void* Jake;
FRC #1178 (DURT)
Jake M has a spectacular aura aboutJake M has a spectacular aura about
Quick EEPROM Question
I know that the EEPROM retains memory values while the RC is off, but does it retain memory when you re-program the RC?
void function(void)
  function();
Unread 18-02-2007, 15:27
gnirts gnirts is offline
Suspicious pointer conversion
AKA: Robinson Levin
FRC #1648 (The Gearbox Gangstaz)
gnirts will become famous soon enough
Re: Quick EEPROM Question
Yes. If you need to clear it, use the EEPROM Wipe .hex file in Kevin's EEPROM code.
I tend to avoid using the EEPROM in a competition setting, though, as it can tie your robot's behavior to something that happened in the last match, etc.
Unread 18-02-2007, 15:28
Kevin Watson's Avatar
La Caņada High School
FRC #2429
Yes.
-Kevin
Kevin Watson
http://kevin.org
quick c question shobuda999 Programming 6 22-02-2005 13:51
Quick Question Burgabot Programming 31 02-12-2003 19:22
Quick <hr> question Jack Website Design/Showcase 1 31-01-2003 22:19
a quick question mike pawlak Championship Event 6 02-05-2002 21:15
A quick question Joelster Technical Discussion 6 10-02-2002 09:09
