Using different Camera Servos
hmm.. we in israel got some of the boxes all wet,
and our camera "jumps" when used, I think it's a servo problem, and would like to test it, at home, as an R/C airplanes pilot I have SANWA standard servos, similiar to the HITECs we got in the kit. am I allowed to use them instead? thanks, Ran. Last edited by 3dude_2231 : 19-02-2007 at 07:02. |
Re: Hi
From what I've heard, you can only use the servos in the KOP on the camera.
Re: Hi
Quote from the GDC at this topic:
Here are <R45> and <R46> just in case you don't know off the top of your head. Quote:
Re: Using different Camera Servos
For those of us in the USA the answer will be no. For teams like yours that are out of the USA FIRST will allow different parts sometimes if the original part is not easily available in your country. Check with Q&A.
thanks,
gonna check that with our local FIRST contact. ![]() |
It might not be the servos!
Check out this thread: http://www.chiefdelphi.com/forums/sh...ight=crosstalk |
#7
I switched the servos as a test,
and it works better by far. it still twiches while disabled, but that's not disturbing. the impotent thing is that it's not jumping like hell when used. it's probably twiching because of it's value in Default_routine() ...it would be changed. ![]() |
