Go to Post With any dollar amount to invest I would be more interested in the number of individuals (students is too narrow) impacted than the number of teams created--after all, this is about people. - kramarczyk [more]
Unread 19-02-2007, 21:30
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Problem with PWM outputs on RC
We've done some testing and have come to the conclusion that many of our PWM outputs seem to be pulsing a signal instead of sending a constant stream.
All of the problems occur outside of the PWMs numbered 3-6. No matter what joystick/device we control the robot with, whichever port we use on the OI, what victor we use, what PWM cable we use, or what motor is hooked up to the pwm signal, the only signals that work properly are motors 3-6.
Is there any way to get a replacement RC delivered to us at the regional from IFI?
Thanks,
Adam
Team 1341 Vice President
Unread 20-02-2007, 06:37
Electrical Engineer
Rookie Year: 1995
Re: Problem with PWM outputs on RC
Originally Posted by Adam Richards View Post
...Is there any way to get a replacement RC delivered to us at the regional from IFI?...
Adam,
Call IFI and get an RMA. Then remove your RC from the robot before it goes into the crate (read this).
The manner of shipment of your replacement or repaired RC is to be determined between you and IFI. I am not sure that they will guarentee to bring it to your competition or not...
Mike
Mike Betts
As easy as 355/113...
PWM Problem with Default Code kbregler Programming 16 03-02-2007 15:14
Vex start up code run PWM outputs without Rx intellec7 Programming 3 05-05-2006 23:29
pwm outputs vs. joystick y-axis stephenthe1 Programming 4 01-12-2004 17:29
Trouble with pwm outputs misterikkit Programming 16 17-01-2004 10:56
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
