pic: 1747 Turret Close up
Re: pic: 1747 Turret Close up
i like the use of ball casters for that big sprocket, it is hard to tell so i'll ask instead of guessing, is that also how you help withstand the forces generated at the rotation point?
Yes the "ball transfers" help distribute the forces away from the rotation point. The "ball transfers" were chosen because they were a low friction method of supporting our arm uprights which are mounted to the sprocket. They also help reduce the amount the arm rocks back and forth when fully extended.
| pic: 1559 Turret mounted | bradleym1559 | Robot Showcase | 2 | 04-02-2006 09:14 |
| pic: Tunring turret | falconmaster | Robot Showcase | 7 | 26-01-2006 17:15 |
| pic: Turret 2 | CD47-Bot | Robot Showcase | 7 | 13-02-2004 19:20 |
| pic: Turret 1 | CD47-Bot | Robot Showcase | 1 | 13-02-2004 01:10 |
| So close, but not close enough | archiver | 2001 | 1 | 23-06-2002 23:45 |
