pic: THINK PINK Roccobot 2k7
Re: pic: THINK PINK Roccobot 2k7
Finally!!! now i can get some rest... it looks great by the way.
Tripple Play anyone? Don't blame you we did the same.
The 2005 robot was the 25 of its year--I can't wait to see how this thing takes on Florida.
Looks like a little bit more swiss cheese has been done to the frame than with the 2006 robot. The wheels also look a little different--care to enlighten us? |
So we made them better. We CNC new wheels that are lighter and slightly stronger than the ones before. Plus it does not require air, so no need to check the air pressure before and after every match. The only thing that remains is the rubber tire part of the pneumatic wheels. We cut the tire out and screwed them onto the wheel. I have a picture of the wheel if you guys really want to see them. |
(For some reason, I just recalled Pink having thick wheels.)Also, dare I think that the arm mounting structure is some shade of gray? |
#7
That arm structure is welded to a metal frame on the inside of the pink chassis. All of that gray area is hollow and is for the large amounts of wiring along with places to mount motors, sensor, etc. Yes, our 2004 and 2005 robot had the arm structure painted pink, but this year, we wanted a good mix of pink and metal because it looks cool. |
#8
I assume you guys will have bumpers in competiton?
#9
You can definitely count on it.
#11
A perfect example of the concept of "Why fix what ain't broke?"
#12
Good Luck
#13
How many telescoping segments do you have on that arm? I am assuming at least 1, but are there more?
Looks like a solid and proven design, can't wait to see it at the championship. |
#14
We have a two stage telescoping arm instead of three like we did with Roccobot 2k4, and 2k5.
#15
you know what i just realized, no CNCed THINK PINK this year? oh well i guess i have to come to expect too much from Pink
| pic: THINK PINK Roccobot 2k7 (side view) | Gabe Salas Jr. | Robot Showcase | 3 | 22-02-2007 09:26 |
| pic: THINK PINK Roccobot 2k6 | Gabe Salas Jr. | Robot Showcase | 25 | 26-03-2006 22:32 |
| pic: THINK PINK Teaser 01 | Gabe Salas Jr. | Robot Showcase | 6 | 15-02-2006 23:53 |
| pic: THINK PINK Roccobot 2k5 | Gabe Salas Jr. | Robot Showcase | 46 | 29-03-2005 17:30 |
| pic: THINK PINK Arsenal | Winged Wonder | Robot Showcase | 7 | 23-02-2005 12:50 |
