Go to Post your time is better spent in the stands, watching what the robots actually do, as opposed to listening to the builders talk about what they're [I]supposed[/I] to do. - sanddrag [more]
Unread 22-02-2007, 19:49
Pnakovich's Avatar
Pnakovich Pnakovich is offline
AKA: Paul Pnakovich
FRC #0612 (Chantilly Robotics)
Pnakovich has a spectacular aura aboutPnakovich has a spectacular aura about
Send a message via AIM to Pnakovich
Objects
does anybody happen to know if there is any type of constraint to stop objects from going through each other or anything
Unread 22-02-2007, 19:52
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Re: Objects
Well, asuming that your working with autodest inventor 10, i'd have to say that you need to put a constraint on your pieces... The tutorial menu should have everything and more to satisfy your needs.
Unread 22-02-2007, 19:58
Pnakovich's Avatar
AKA: Paul Pnakovich
Re: Objects
i use inventor 11, and what im talking about is say that you have two objects constraint at one point using a hinge, and when i move them closer, one part keeps on moving right through the other part
Unread 22-02-2007, 20:22
CraigHickman
Posts: n/a
Re: Objects
I haven't taken the tutorial yet, I plan to do so later this week, but I know that contact sets are exactly what you're looking for.
Unread 22-02-2007, 21:18
Pnakovich's Avatar
AKA: Paul Pnakovich
Re: Objects
thanks for the tips i finally got it
Unread 23-02-2007, 23:29
Pnakovich's Avatar
AKA: Paul Pnakovich
Re: Objects
this may not fit in this area, but there is a problem while trying to add text, the window comes up and i can add words in the edit window, but when i finish there is nothing in the drawing, or just the outline box with no words. anybody now how to fix this or know what this is.
Unread 26-02-2007, 07:14
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: Objects
http://usa.autodesk.com/adsk/servlet...linkID=4183228
Unread 26-02-2007, 07:46
Pnakovich's Avatar
AKA: Paul Pnakovich
Re: Objects
i already tried that and couldn't find anything with that name on the list.
Unread 26-02-2007, 10:44
rohit's Avatar
rohit rohit is offline
Inventor Person
FRC #0617 (The Springers)
rohit has a spectacular aura aboutrohit has a spectacular aura about
Send a message via AIM to rohit
Re: Objects
but contact sets only work when you're animating. What if you made the robot assembly using axis constraints because you want to show how the robot works by being able to drag it? if you know what i mean
Unread 26-02-2007, 10:49
JD Mather's Avatar
Re: Objects
Be sure to click the Show Updates at the top right corner of the dialog box. For some reason I had trouble finding the checkbox the first time I looked even though I new what I was looking for.
After removing I would turn off Automatic Windows Updates - then only check for updates every once in a while and only install after they have been tested by everyone else.
Unread 26-02-2007, 10:53
Brandon Holley's Avatar
Re: Objects
Transitional Constraint.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 26-02-2007, 11:16
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (EarthQuakers)
Re: Objects
I imagine the text is on your sketch. To be able to see the text, you need to make your sketch visible.
Remember that when you make the sketch visible, all other shapes and dimensions on that sketch will also become visible.
Good luck!
Hi!
Unread 26-02-2007, 15:26
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Re: Objects
This sounds like a job for Dynamic Simulation!
As for your text problem, you need to type the words out in a paint document, import the document into a new sketch, and decal it on.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 26-02-2007, 16:42
GMAdan's Avatar
GMAdan GMAdan is offline
Team member turned mentor
AKA: Daniel A. Cobar
FRC #1881 (GAMMA Elite)
GMAdan has a spectacular aura aboutGMAdan has a spectacular aura about
Send a message via AIM to GMAdan
Re: Objects
I am having a similar problem but not in idw but in part files. I want to engrave some letters on parts but when i click ok only the dotted lined box shows up. Does that solution also work for my problem?
Unread 26-02-2007, 19:44
Pnakovich's Avatar
AKA: Paul Pnakovich
Re: Objects
i'm sorry for any confusion, it's not the .idw file that the problem is in it's in the .ipt file for the part. Also when i clicked on the updates box in the window i still couldn't find the hotfix update it talked about. I couldn't find a visibility option in the sketch. And I also want to use the text tool for engraving,but when i try to make the text come up it comes up with just the dotted line box but only when i try and edit it. And when i try and put in a picture into the part it comes up with an error. I think it's only on my computer because when I tried it on a computer at school it work, but unfortunatley I have limited time to work at school.
Extending objects Booger Inventor 10 14-07-2006 13:04
Making objects invisible sciencenerd Chit-Chat 1 31-05-2006 06:31
Combining objects in 3D studio? DinkyDogg Inventor 6 31-01-2005 17:09
Adding objects Matthew_H 3D Animation and Competition 5 12-02-2004 19:33
