Go to Post "Who needs finesse when you have air pressure?!" - neelpatel1710 [more]
Unread 23-02-2007, 14:21
hanspflaumer hanspflaumer is offline
FRC #2129 (Ultraviolet)
hanspflaumer is an unknown quantity at this point
VICTOR 883/884 HELP
Hello there! can anyone pass me some pictures of a victor taken apart so i can see the insides of the PCB, etc? or any ideas on how to make one of these?
Thank you!
Unread 23-02-2007, 15:21
Re: VICTOR 883/884 HELP
hans,
pictures will not help you reverse engineer this device. It has a dark conformal coating on both sides and the part numbers are mostly covered as well. Most people can tell you it is a standard "H" bridge motor controller with three FETs in each leg. There is a Pic controller on board, as I remember, to decode incoming PWM, provide drive, calibration, LED decoding and drive. Add to that, the interface drive parts for the gates of the FETs plus some drain equalizing resistors for each FET and that about fills up the board. Most of it is surface mount as well.
Unread 23-02-2007, 18:14
Racer26 Racer26 is offline
my question would be why you would want to make one? One you made yourself would CERTAINLY not be FIRST-legal, and probably cost you more to make than buying it from IFI anyway.
Victor 884 light. ForgottenSalad Control System 3 01-02-2006 01:25
Recalibrating Victor 884 Greg Electrical 8 18-02-2003 14:07
Victor 884 Kevin Ray General Forum 25 28-01-2003 15:02
victor 883/884 Brett W Technical Discussion 21 08-01-2003 20:36
Victor 884 Gary Bonner Technical Discussion 4 14-01-2002 08:10
