Go to Post ...some of our robots could use a proctologist - Scott Ritchie [more]
Unread 23-02-2007, 17:42
Best Available Data
FRC #1778 (Chill Out!)
pic: 1276's 2007 3-Speed AM Gearboxes
Last edited by Ian Curtis : 23-02-2007 at 21:13. Reason: Added text from original post.
Unread 23-02-2007, 17:44
crazykid234's Avatar
crazykid234 crazykid234 is offline
Techincal assist
AKA: Brian Clegg
FRC #1646 (Precision Guessworks), Alumni FRC #234 (Cyber Blue)
crazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to beholdcrazykid234 is a splendid one to behold
Re: pic: 1276's 2007 3-Speed AM Gearboxes
ok, I'll be the first to say that is awesome!!!!!!!!!
What kinds of speeds do you get?
Have you discussed this design with AndyMark to see if maybe they'll market it for next year?
Don't see the world as it is and ask why; see the world as it could be and ask, why not? - unknown author
Unread 23-02-2007, 17:49
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Gah.
Here I was expecting to see what kind of beast 1276 will put out this year!
I guess I'm just going to have to wait another week...
Those are looking pretty sweet. We were the development of a 2-speed ball-lock shifting transmission before kickoff. This is kind of convincing me to try to work on a 3-speed.
Good luck at BAE, guys.
The sign applause was definately one of the best moments I had ever witnessed at a FIRST event.
Who knew silence could be so loud?
Mayhem in Merrimack hosts: 2005-2016 - Week Zero hosts in partnership with FIRST HQ: 2014-2016
Unread 23-02-2007, 20:33
Best Available Data
Around 4fps in low gear, 10fps in medium gear, and 15fps in high gear.
We haven't showed them to AM (but I expect they'll see it here). They aren't bullet proof like the 2 speed, without proper code and additional sensors it is possible to lock them up.
Unread 23-02-2007, 20:56
Billfred's Avatar
Billfred Billfred is offline
When they do get locked up, is it possible to unlock them? Then it quits being a bug and becomes a feature.
Like the mods--nice and clean!
Unread 23-02-2007, 21:02
AdamHeard's Avatar
Lead Mentor
Yeah. If it is controllable then you have a 3 spreed transmission with brake....
so... is it?
Best Available Data
It is very possible to unlock, just shift the third gear dog back into neutral. The only real problem is if you were cooking across the field at full speed and then locked them up you might do some damage.
EDIT (In response to Sean): Yep, that's what I figured too. It's just that if you engaged it while you were driving, you could hurt something.
Unread 23-02-2007, 21:05
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I think he was referring to intentionally locking them up to create a mechanical braking feature.
The biggest issue about using the dogs to lock up the shifters is what happens when it does fail. If you accidentally lock up the gears (which may happen if you have a lock on command feature), or you recieve a significant force to the gearbox when locked up (not sure what force this could be, most external forces this large would probably just cause the wheels to skid well before a failure in the drive) the failure would almost certainly be losing gear teeth. And that spells disaster in a transmission.
Unread 23-02-2007, 21:08
AdamHeard's Avatar
Lead Mentor
That is awesome then. Keep your code so you don't look them at high speed, but also put some code in that let's you lock it on command. It would be really useful for holding position on a ramp at the end of the match.
Unread 06-03-2007, 17:02
Best Available Data
In case anyone is wondering, these gearboxes held up perfectly through our regional. There was never any "bad shifting" causing a lockup or teeth stripping or anything of that sort. We found the extra high gear most useful in this years game to race around the rack to play defense and then return.
If there is any interest, we plan on creating a white paper before next season. (There, a deadline, now I'll have to follow it. )
Unread 23-02-2007, 20:57
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Aaaaah! I think my head just exploded from looking at this awesomeness. You guys are great. This is super cool.
I thought Kaizen Blitz was working on something interesting, as I noticed they were buying a few extra parts... but I would not have guessed this.
For all of the people who think that selling off-the-shelf gearboxes stifles the engineering and creativity of FIRST teams ... phooey on you... look at 1276 and what they have done. Excellent job!!!
Andy B.
pic: Outback system with modified Andy Mark gearboxes sam shawe Extra Discussion 5 21-02-2007 12:56
pic: Team 948 2-Speed Gearboxes jfelser Technical Discussion 10 08-02-2007 23:26
pic: 1276's Handouts Ian Curtis Extra Discussion 11 02-02-2007 17:03
pic: 1276's 2006 Robot Ian Curtis Extra Discussion 8 17-04-2006 21:30
pic: Team 1114 Gearboxes CD47-Bot Robot Showcase 16 19-02-2004 12:16
