Go to Post As my boy Macklemore once said, "The greats weren't great because at birth they could paint, the greats were great because they paint a lot". - Andrew_L [more]
Unread 24-02-2007, 21:50
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
Vex Servos
Is there a datasheet somewhere for a VEX servo? I looked on Vexlabs and was unable to find one. I wanted to look at the control operation range of the input pulse. I know some servos are 1 - 2 ms but the vex servo doesn;t operate at full performance there. I have found it to go to outside of the 1-2ms pulse range.
Also does anybody have a PWM signal explantion for servos? on the uC I used phase correct and that didn't work. So I had to switch to Fast PWM mode.
Thanks,
-John Gutmann
Unread 24-02-2007, 23:25
Gdeaver Gdeaver is offline
FRC #1640
Re: Vex Servos
On most servos the 1 to 2 ms will not give the full physical range that the servo is capable of. This is done so that any physical shock will not force the shaft to go to the physical stops. You can get more range out of some servos by sending pulses shorter than 1 ms and longer than 2 ms. I did this for a IR ranging sensor. The Hitec servo in the FRC KOP is capable of slightly more than 180 degrees.
Unread 26-02-2007, 17:31
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
Re: Vex Servos
Yea I jsut wasn't sure what the max range is to use (safely). for using the continous rotation servo I am running it at about 122 Hz and have a range of about 5 bits on a 8 bit timer. I was thinking of bumping up to a 9 or 10 bit timer to increase resolution, in the servos range.
But I now successfully have a VEX robot running off a Atmel uC! I just need a bettery good enough to supply the power for 4 servos!
-John
Vex servos burkechrs1 Motors 3 08-01-2007 17:59
VEX servos JasonQ FIRST Tech Challenge 2 07-12-2005 15:14
servos AlphaOmega870 General Forum 1 21-01-2004 17:37
Servos Element945 Electrical 2 10-02-2003 13:32
Servos... Katie Reynolds Motors 8 14-01-2002 08:08
