Go to Post So, apparently I have my own division in nationals going by the search, "elgin clock division". Why was I not told about this? jeesh... - Elgin Clock [more]
Unread 27-02-2007, 23:55
Robo_Cat_379's Avatar
Robo_Cat_379 Robo_Cat_379 is offline
AKA: Zach
FRC #0379 (Robocats)
Robo_Cat_379 is an unknown quantity at this point
Send a message via AIM to Robo_Cat_379
pic: 379's transmission
Unread 27-02-2007, 23:57
seinchin seinchin is offline
AKA: Kevin
FRC #4144 (Semi-Con-Duck-tors)
seinchin is an unknown quantity at this point
Re: pic: 379's transmission
Are you using a tread drive?
Unread 28-02-2007, 00:41
CraigHickman
Posts: n/a
280 foot pounds... I'm slightly tempted to doubt this number, as a racing mustang I work on with a fully aftermarket engine, and all performance parts puts out 298 at 2100 rpm... Where did you get this number?
Unread 28-02-2007, 01:00
gburlison gburlison is offline
gburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to allgburlison is a name known to all
Well,
If I did the conversions right, the small CIM puts out about 1.27 foot pounds of torque at stall or 0 rpm. That means that a 221:1 gear ratio would equal about 280 foot pounds of torque at 0 rpm (stall). I have no idea if this transmission has a gear ratio near 221:1
How much torque does that Mustang motor put out at 0 rpm?
Gordon Burlison - Mentor
662/Rocky Mountain Robotics
"Every silver lining's got a Touch of grey - Robert Hunter"
"No sense in being pessimistic, it wouldn't work anyway"
Unread 28-02-2007, 01:04
CraigHickman
Posts: n/a
0 rpm doesn't happen in a internal combustion engine, as the motor is not turning. I have a feeling they did their calculations based on the max rpm of the motor, or 5200 rpm.
Unread 28-02-2007, 07:39
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Wow... 280 thats intense.... We are pushing around there, but in order to do so we had to do a serious friction increase project. Have you found out if you have any slipping going on or are you alright in that area? Other wise that is a SERIOUS gear system and looks great. We have a shifting mecognism that we think will really impress some people. But all in good time right . Other wise this looks like a great drivetrain that I am pretty sure will work very good. From experience I can say that being able to push 280 means pushing someone sideways wich translates into a HUGE advantage in the game. If you have designed this bot as a great bully bot then you did a great job! If you dident you still did a great job. One more question that I have to ask though is how fast does this drivetrain go? Usually with low gearing and not being able to shift you have high torque and low speed. Is the same true with your bot? Thanks, and I wish you and your team the best of luck at regionals.
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 28-02-2007, 11:45
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
So 24 RPM for the output?
How much do your gearboxes weigh?
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 28-02-2007, 20:05
Sorry, but my odd sense of sarcasm doesn't come across well online. Specs for internal combustion engines usually quote a torque and speed so that you have a better idea of what the engine is capable of. I assume that these claims are all based on calculations and are not actual. The point is that PM electric motors and internal combustion engines are very different and most of the time comparisons are not very usefull. I agree that the probably used 5200 rpm and their highest gear ratio to calculate the 15 fps. But they probably used stall torque and the lowest gear ratio to calculate torque not realizing that at stall the CIM draws 133 amps, so they will not produce 280 ft-lbs of torque for very long.
Unread 01-03-2007, 12:29
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
I'm not exactly sure about the calculations, but from my experience, this transmission is very powerful. I cannot recall a time that this Drive system has lost a pushing match. It is a 3 speed transmission that weighs a total of 25-30lbs, it is also combined with the traction of treads and slippage is not an issue.
Unread 01-03-2007, 21:14
Imaginary Friend
AKA: Kevin Li
Team Role: Student
Yes but how fast do you move with that 221 reduction?
Kevin Li
596 - Sciclones
Unread 05-03-2007, 08:48
Hadi379's Avatar
FRC #0379
I believe its fastest speed is about 15 fps
pic: 2 Speed Transmission AustinSchuh Extra Discussion 20 30-12-2006 16:39
pic: 2 speed transmission 1 psyco_klown Extra Discussion 3 05-09-2006 19:03
pic: 2 speed transmission 2 psyco_klown Extra Discussion 0 22-05-2006 13:35
pic: 379's 2006 Robot Cat 7 Robocat1 Robot Showcase 16 05-03-2006 12:20
pic: 1141 gets under 379's skin CD47-Bot Extra Discussion 2 06-04-2004 09:27
