Anyone lost thier BaneBots Carrier pins?
During our last match today, we lost one side of our drivetrain, and were unable to drive around. When we took apart the BaneBots gearbox, all 5 of the pins in the carrier plate had come out of the carrier plate, so that the output shaft spun freely.
This is with the new hardened carrier plates, in a 2-CIM 12:1 gearbox.Has anyone else had this problem? |
Re: Anyone lost thier BaneBots Carrier pins?
I did notice that when I put the new plates in that they were really just pins stuck inside a through hole, unlike the other plate which had pins in a partial hole. Thanks for getting this out, now it ours fails I'll know what's wrong with it.
Banebots, in a hurry to get these new carrier plates out, had to substitute a standard pin that they could easily obtain in place of their own, longer pin. Therefore, the pins are a bit shorter. I guess the lack of engagement inside the hole is allowing the pins to back out in operation.
I suppose teams should press the pins back out and use some press-fit loc-tite to retain them. That seems like the easiest solution. Any team with an arbor press should be able to take care of it in a few minutes. |
There was one report of this problem from a team at St. Louis. I believe the team was 525. Hopefully someone from that team will provide more details.
From what I heard this happened to our team (I'm a programmer, but I think this is what happened.)
We have pictures of the carrier plate somewhere... |
Re: Anyone lost their BaneBots Carrier pins?
I wasn't there when it happened, but we apparently lost the pins on the other side this morning. We had been playing a lot of defense. Unfortunately, there's no good way to check for the problem without taking apart the gearbox, and when it fails, it fails completely.
We had noticed difficulty making left turns sometimes, and backing up made the problem go away. This might be a warning sign, but we need more evidence to prove it. |
#7
Well, I guess we won't be using these transmissions next year.
We will pull them out and rebuild them for our next 2 competitions. Does anyone know the precise diameter of the pins? I think if we insert a short pin into the top of the planetary gear, this may prevent the longer pin from coming out, in addition of course to putting some thread locker on the ends of the long pins. |
#9
Team 1323 had one of our transmissions lock up. We were running the two CIM adapters to the kit banebot transmission with a new carrier plate and the spur gear in the center had pushed the inner carrier plate out and was making the Global Gears bind. Team 1778 in the pit next to us had this happen twice with two different Transmissions and they were only running one CIM to them. Anyone else have this problem
#10
We had this happen in testing. Locked up so bad couldn't turn it with a 5" wheel on it. Single CIM, 40lb bot, slippery surface. Took it apart, greased, put back together, ran like butter.
#11
Yes, it has happened to us, multiple times. Those carrier pins shoot out after less than an hour of driving on our robot- and we are simulating competition defense. This really is not good.
#12
We had the same problem - the pins came out of the new carrier plates and one of the planet pinion gears stripped. I posted a long explantion on this Our Banebots Experience thread.
#13
We lost all of the pins in one box during matches on friday. That night, I had the other spare set of plates that we had welded an ground down. On Saturday morning when I replaced them, the one box had all the pins missing, another had one missing, and a third had 4/5 missing
Beware teams.... Beware! Jacob |
#14
I'm not sure that I understood your comment. Did you mean to say that the welded in pins also came out?
#15
We decided to follow Team 237's advice and spot welded the back of the pins to the carrier plate. The welds stuck up a little (maybe a 1/16th of an inch) but it cleared the outer housing, so no grinding was required. When we went to re-assemble the plates, we found that at least one of the pins on each of the carrier had lost its perpendicularity, and kept jamming up the stage. So, we ended up running both gearboxes with only 4 of the 5 planet gears in them.
We ran 10 matches, 4 practice rounds, and about a hour of practice on the practice field -> No Failure! We haven't taken them apart to confirm their health, but I'm fairly confident that they held together without losing any pins. We'll be double-checking for our post-season comps. Best of luck, BEN |
| Rochester Democrat and Chronicle Gives Local FIRST Team Thier Own Spotlight | Koko Ed | FIRST In the News... | 27 | 30-01-2008 11:51 |
| pic: Carrier plate | deathbycornchip | Extra Discussion | 2 | 18-02-2007 10:51 |
| pic: Pins Pins and more pins | CD47-Bot | Extra Discussion | 26 | 04-09-2005 23:07 |
| who has combined PVC tubing for thier frame? | Alex Cormier | General Forum | 8 | 12-12-2004 19:47 |
| Drill Motors: Pins IN or Pins OUT | Caleb Fulton | Motors | 28 | 03-02-2003 14:19 |
