Urgent help with a project;
So Im trying to put a turbine assembly on a car to generate electricity when slowing down ie. braking. This hwould allow a gas car to recoup some electricity when braking. Is there a way through CAD to simulate the energy generated by a turbine in a certain wind speed? Could I test out different turbines with this? Im sure there is some program to do this but I could not find one.
Re: Urgent help with a project;
I'm trying to imagine what you have in mind, and can't do it.....how about a sketch to help explain it?
It sounds like you're trying to make a hybrid gas/electric car, the hard way. |
A wind turbine is probably one of the least efficient ways to recover energy from vehicle speed. You might consider connecting the input of a generator to a rubber wheel that can be pressed against one of the drive wheels as a dynamic brake. |
Dassault Systemes makes two CAD suites that allow for CFD.
If you have the full version of Solidworks (link), you can use the COSMOSFloWorks add-in to preform a flow analysis on a part you've made in solidworks. The other Dassault product available is CATIA (link) . CATIA requires the Fluent (link) plugin, but provided that you have both, CATIA can also preform CFD. Hope this helps, Mike Last edited by mgreenley : 05-03-2007 at 13:45. |
| URGENT! We need help with the accelerometer | lkdjm | Electrical | 5 | 11-02-2005 16:42 |
| URGENT! We need help with the accelerometer | lkdjm | Technical Discussion | 0 | 08-02-2005 14:35 |
| Need help with Data recovery [urgent] | plutonium83 | Chit-Chat | 7 | 11-01-2005 10:35 |
| help with simple project | erikh98 | Technical Discussion | 8 | 27-08-2004 11:24 |
