Go to Post Good thing you skipped this year. You don't need exhaustion to sleep through Recycle Rush. - Gregor [more]
Unread 06-03-2007, 19:52
Evil Asian's Avatar
Evil Asian Evil Asian is offline
AKA: Kevin
FRC #2140 (Team Synergy)
Evil Asian is an unknown quantity at this point
Send a message via AIM to Evil Asian Send a message via Yahoo to Evil Asian
Arms
in the passed year is there some thype of arm you use????????? and is it better to use air Lines to run the arm???? or motors in the kit?????
Unread 06-03-2007, 20:23
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Re: Arms
This year our team used a 2-segmented arm where the 1st part "tower" is attached to the chassis and the 2nd piece is rotated using the globe motor.
Now by air lines i'm guessing u mean pneumatics? well, we didnt use pneumatics this year but on our '05 robot we did. Then, we had a 3-segmented arm where the second piece was elevated by a large pneumatic piston, then the third section was rotated using the van-door motor (we didn't get that this year ). The thing with pneumatics is that they can only go fully open or fully closed, there is no middle ground like with hydrolics. So if u only want your arm to go to a certain position then pneumatics would work but otherwise i'd go with motors. Also pneumatics are heavy (u got the compressor, all of the regulators, hose, at least 1 tank, and then the pistons) so you'll need keep that in mind as well.
Unread 06-03-2007, 20:30
triggerhappy336's Avatar
triggerhappy336 triggerhappy336 is offline
Driver
AKA: Craig Porter
FRC #2228 (CougarTech)
triggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of lighttriggerhappy336 is a glorious beacon of light
Send a message via AIM to triggerhappy336
Re: Arms
We used pneumatic's. We used pneumatic's for allot of stuff. Once we threw the compressor on we figured we might as well get the most use out of it. Which is pretty cool cause I like pneumatics.
So I'm pretty biased, I say it's better to use pneu than motors.
If they would let me, I would have our bot be a hover craft off that compressor. That would be wicked
EDIT: Well for our arm extention we used motors, that's a good way to go. As the above poster said you need middle ground for the extention. Plus I don't think they're are pistons big enough to go to the top leg.
Unread 06-03-2007, 20:34
Render Render is offline
AKA: Robert Udicious
FRC #1885 (Robocats)
Render will become famous soon enoughRender will become famous soon enough
Re: Arms
90 pts!
2007 - NASA/VCU Quarter finalists
2006 - Championship Event Rookie All Star winners
2006 - Palmetto Rookie All Star Award winners
2006 - NASA/VCU Rookie All Star Award winners
Attending:Las Vegas Regional, Championship Event
Unread 06-03-2007, 20:44
run the trap!!!
Team Role: Human Player
Re: Arms
Over the years we've done both pneumatics and motors.
We haven't had much luck with the pneumatics. The compressor barely squeeks out enough air to run an arm an entire match. To get enough air you have to add more cylinders, which adds more weight. The Kop pneumatic conectors are also unrelaible, which leads to leaks and the loss of more air.
Motors have their own problems: backdrive, breaker blow-outs, and (in the case of the Keyangs and windows) cracking plastic gears. However, electons don't tend to leak out, and the battery isn't part of the wight So you don't have to worry about losing power.
Another major problem with pneumatics is that they are not linear. The actuators have only two positions -extended and contracted. Pnemuatics are not good at raising an arm precise amounts.
-Philip J. Fry
Unread 07-03-2007, 00:57
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Re: Arms
We had a lot of success with pneumatics on our grabber in 2005 (which was extremely heavy and coupled with a fairly robust elevator). Admittedly, we had to cheesehole off about 10 pounds because of the extra weight from the pneumatics, but it worked really nicely.
We were originally going to use pneumatics on this year's grabber as well, but our jointed arm couldn't handle the torque caused by the piston on the end so we switched to a globe motor.
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 07-03-2007, 11:36
fluffy's Avatar
fluffy fluffy is offline
What color was that wire again?
AKA: David
FRC #3663 (CPR)
fluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to beholdfluffy is a splendid one to behold
Send a message via MSN to fluffy
Re: Arms
we have two pistons for the grabber
and a globe for raising the arm
giving us the best of both worlds
http://www.chiefdelphi.com/forums/sh...threadid=55336
Unread 07-03-2007, 18:38
Evil Asian's Avatar
AKA: Kevin
Re: Arms
thank you all for your help
Unread 07-03-2007, 22:33
Dominicano0519's Avatar
Dominicano0519 Dominicano0519 is offline
My team is not competing this year
AKA: Demolition Man
FRC #0381 (Tornadoes)
Dominicano0519 will become famous soon enough
Send a message via MSN to Dominicano0519 Send a message via Yahoo to Dominicano0519
Re: Arms
we used motors and a very elaborate pulley system or the arm
Favorite Phrases:
1. I like your robot, no-homo
2. "It depends how you define alone" ( Bill Clinton when being questioned about Monica Lewinsky)
Unread 07-03-2007, 23:50
meatmanek meatmanek is offline
Programmer/physicist/mathematician
FRC #0868 (TechHounds)
meatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to beholdmeatmanek is a splendid one to behold
Re: Arms
Yeah, I've been thinking about that. I think with creative use of solenoids, valves that restrict airflow, good sensors, and nice code, a team could manage to make a pneumatic servo that used minimal air. The more I think about it, the more possible it seems.
Here's someone who's done it:
http://robotics.mcmaster.ca/Videos.htm#pneumatic
Real programmers use vim.
Unread 08-03-2007, 00:01
run the trap!!!
Re: Arms
I too have heard about people pressurizing both ends of an actuator to operate it linearly. But getting this to work would be a lot harder then using a motor.
-Philip J. Fry
Unread 08-03-2007, 00:12
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Arms
It all depends on the precise tasks you're trying to accomplish. I'll cover some of 116s arms I'm familiar with.
2001- pneumatic shoulder joint raised arm from folded position into scoring position. Motor controlled elbow and wrist joints. The gripper was also actuated by pneumatics. Placed large balls on goals, as well as folded up to fit under the bar.
2004- Globe motor powered shoulder. Pneumatic extension. Pneumatic gripper. Could place large doubler balls as well as hang on bar at end of match.
2005-Window motor powered winch. Pneumatic extension created lever for winch. Pneumatic gripper prevented tetras from flying off of arm. Arm could manually load tetras and score on any goal.
2007- 2x Globe motors power shoulder. Pneumatic wrist actuation, and pneumatic gripper. Surgical tubing powered single-time extension (fires when disengaged from locking mechanism at beginning of each match, then locks in extended position). Picks up tubes from ground and scores on all 3 levels of the rack.
Unread 08-03-2007, 07:28
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Arms
Just as a rule of thumb... motors, because of the small compressor, tend to be faster at actuating manipulators n such, just because of the low cfm of the thompson compressor. We had a pneumatic actuator on our tetra bot... and it did slow us down some.
This year... motor drives on the elevator.... bottom to top (top row score) about 1.5 seconds give or take
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 08-03-2007, 08:19
Jimbo5051's Avatar
Jimbo5051 Jimbo5051 is offline
Rep' da Goat
AKA: Jimmie Nickerson
FRC #0829 (The Digital Goats)
Team Role: Electrical
Jimbo5051 is an unknown quantity at this point
Send a message via MSN to Jimbo5051
Re: Arms
We used little BaneBot motors with a planetary gearbox, it seemed to work fine except when we tried to use them with the up/down part of the arm (we burned up 2 Banebots.)
2007 St. Louis Regional Winners
Unread 08-03-2007, 16:43
cziggy343's Avatar
cziggy343 cziggy343 is offline
cziggy343
AKA: Chris Z
FRC #0343 (Metal-in-Motion)
cziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond reputecziggy343 has a reputation beyond repute
Send a message via AIM to cziggy343
Re: Arms
this was done with motors.
Diamond Bullet Studios Co-Founder
http://www.dbsgames.net/index.php
Turreted Arms Jonathan Norris Technical Discussion 14 11-01-2007 13:24
Arms anyone? 6600gt Technical Discussion 15 10-01-2007 19:23
Lowering of Arms bayside Technical Discussion 2 03-03-2006 07:22
pneumatic arms Jesse Control System 1 06-02-2004 15:41
Arms mikeL 177 General Forum 2 19-02-2003 11:15
