Go to Post I am used to politicians getting up and being blowhards. - Steve W [more]
Unread 07-03-2007, 16:44
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
03/07/2007 USFirst Site down
Anyone else having problems with the FIRST site? I'm just getting this:
Could not load file or assembly 'App_Web_erklobc_, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.FileNotFoundException: Could not load file or assembly 'App_Web_erklobc_, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Assembly Load Trace: The following information can be helpful to determine why the assembly 'App_Web_erklobc_, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' could not be loaded.
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
Stack Trace:
[FileNotFoundException: Could not load file or assembly 'App_Web_erklobc_, Version=0.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.]
ASP.includes_navigation_ascx.__BuildControlTree(in cludes_navigation_ascx __ctrl) +0
ASP.includes_navigation_ascx.FrameworkInitialize() +19
System.Web.UI.UserControl.InitializeAsUserControlI nternal() +31
System.Web.UI.UserControl.InitializeAsUserControl( Page page) +14
ASP.homepage_master.__BuildControlNav2() +49
ASP.homepage_master.__BuildControlform1() +81
ASP.homepage_master.__BuildControlTree(homepage_ma ster __ctrl) +114
ASP.homepage_master.FrameworkInitialize() +34
System.Web.UI.MasterPage.CreateMaster(TemplateCont rol owner, HttpContext context, VirtualPath masterPageFile, IDictionary contentTemplateCollection) +1980912
System.Web.UI.Page.get_Master() +48
System.Web.UI.Page.ApplyMasterPage() +18
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +543
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET Version:2.0.50727.210
Unread 07-03-2007, 16:45
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
Re: 03/07/2007 USFirst Site down
yup
also noted here
VanMan's Avatar
VanMan VanMan is offline
NCSU student
AKA: David VanLeeuwen
no team (Team Awkward Turtle)
VanMan will become famous soon enough
Send a message via AIM to VanMan
Yeppers
2010-present - NC State University Underwater Robotics Team
ncsurobotics.com
2007-2009 - FRC 2108
2006 - FRC 926
Unread 07-03-2007, 16:46
Brian J. R.'s Avatar
Brian J. R. Brian J. R. is offline
Pit Chief
AKA: Brian Richards
FRC #1983 (Skunkworks)
Brian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to beholdBrian J. R. is a splendid one to behold
Send a message via AIM to Brian J. R. Send a message via Yahoo to Brian J. R.
I have gotten that recently as well. Probably because they are changing it again or updating the stats (something along those lines....not a web master speaking here).
Brian Richards, 1983 Mechanic
Unread 07-03-2007, 16:47
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
I've used ASP.net, and that is what it looks like.
Eric Haskins KC9JVH
Unread 07-03-2007, 16:51
RoboMom RoboMom is offline
people expediter on Team Kluge
AKA: Jenny Beatty, no relation
no team (they are all my teams)
RoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond reputeRoboMom has a reputation beyond repute
IT is working on it.
Co-Founder of NEMO (Non-Engineering Mentor Organization) www.firstnemo.org
Volunteer Director, STEMaction, Inc. www.stemaction.org
FIRST Senior Mentor: Nov. 2004 to June 2009: "Experience is that marvelous thing that enables you to recognize a mistake when you make it again"
This is How I Work: http://www.chiefdelphi.com/media/papers/2862
Unread 07-03-2007, 16:54
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Not certain what you were trying to look at on FIRST's site. I keep two FIRST sites in my favorites: The second is for the FIRST FORUMS:
http://forums.usfirst.org/
I just checked it and it looked like it was still working OK.
Unread 07-03-2007, 17:24
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
dosent work for me either......no offense intended but i use php and have never gotten any major errors (mostly missed ";")....lol hope first can get it fixed soon.
/forest
Unread 07-03-2007, 17:34
dbell dbell is offline
Mentor for team#3937 (Breakaway!)
AKA: David Bell
FRC #1519 (Mechanical Mayhem)
dbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to beholddbell is a splendid one to behold
Unhappy Re: 03/07/2007 USFirst Site down
i get that too.
hopefully it will be gone soon.
Unread 07-03-2007, 17:43
Nick 1523's Avatar
Nick 1523 Nick 1523 is offline
Robot Manager
AKA: Nick Clark
FRC #1523 (M.A.R.S.)
Nick 1523 is an unknown quantity at this point
Send a message via AIM to Nick 1523
i'm glad it's not me just me that's having this problem, but i hope it's fixed soon
Unread 07-03-2007, 17:49
ham90mack's Avatar
ham90mack ham90mack is offline
President of RIT FIRST
FRC #0073 (The Illumination)
ham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really niceham90mack is just really nice
It's been down for over two hours, I hope they can get it fixed sometime soon...
Unread 07-03-2007, 19:19
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
http://www.usfirst.org/
its up and running for me.
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 07-03-2007, 19:25
petek's Avatar
petek petek is offline
What would Dave do?
AKA: Peter Kieselbach
FRC #3654 (Tech Tigers)
petek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond reputepetek has a reputation beyond repute
Send a message via AIM to petek
Probably was just swamped with all the people looking to see if team update #17 had been posted.
Pete Kieselbach
Unread 07-03-2007, 19:50
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
Yep, looks like its back up now.
Autodesk Streamline site down? Jeremiah Johnson 3D Animation and Competition 0 16-01-2005 18:51
First site down? phillutz Technical Discussion 4 15-01-2005 12:11
New Look at the usfirst site archiver 2001 8 24-06-2002 02:37
FIRST WEB site down archiver 2000 7 23-06-2002 23:45
FIRST site down - help Ben Mitchell Chit-Chat 5 28-04-2002 18:19
