Go to Post some people sing in the shower........i pretend to be an emcee at championships......:cool: - BanksKid [more]
Unread 12-03-2007, 00:41
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
Jump Drives as Data Recorders.
I remember a while back reading a topic on how you could attach a jump drive to your RC and collect data throughout matches giving you a better idea to isolate problems that may occur.
I was wondering if anyone could please guide me in that direction, because after searching CD, I am still where I started, Confused.
Thanks.
EDIT:Found the topic at last. Here.
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 13-03-2007, 13:09
ericand's Avatar
ericand ericand is offline
AKA: Eric Anderson
FRC #3765 (Terrabots)
ericand is a jewel in the roughericand is a jewel in the roughericand is a jewel in the rough
Re: Jump Drives as Data Recorders.
The thread that I recall talked about using an SD card mounted with a serial interface, using DOS on Chip. The thread is in the programming system and refers to a file system for the RC (from December 06). I found it again by looking for "DOS on Chip". The url of the forum page I found is:
http://www.chiefdelphi.com/forums/sh...ht=DOS+on+chip
Unread 13-03-2007, 13:21
If you dont need to save a lot of data you can use the dashboard and record on your laptop.
Unread 15-03-2007, 14:34
JimGRobot JimGRobot is offline
AKA: Jim
FRC #1388 (Eagle Robotics)
JimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really niceJimGRobot is just really nice
I started the Chip DOS thread last year after doing some preliminary work with reading SD chips, I haven't tried writing to them yet, but it can be done.
I haven't worked on it since build-season started, but there is a bunch of info on a blog I started here: http://www.techranch.com/blog/
I hope to create a small code library that will make it easy to interface this with the RC, but this project is on a list with others... ;-)
Thanks,
Jim
Unread 28-03-2007, 18:27
Pavan Dave's Avatar
Busy in College
Thanks,
Jim
Thanks for the help Jim. This is my summer project, trying to get one of the two devices listed on this thread to work so if I meet success I will try and post a white paper, but that is if I can get all the parts to do this.
Pavan.
1745 - 118 - ΔΕΨ
Unread 28-03-2007, 21:06
Gdeaver Gdeaver is offline
FRC #1640
Jump drives involve usb. SD cards need SPI. Perhaps the easy way to add SD card data storage and logging to the FRC is to use a PIC 18 as a interface between the FRC and SD card. Use the pic to take a ttl serial from the FRC and the massage it and send It out the SPI hardware port. If you look at this link This PIC chip has all the libraries done for you to interface to the SD card and there are high level serial functions to handle the FRC side.
http://kronosrobotics.com/Projects/MMC.pdf
Take a look at the Kronos site while your at it. The Dios chip language provides a large library of functions and routines that handle the low level stuff.
Seeing is believing...needed: video recorders w/e 3, 4, 5. soap108 General Forum 12 12-03-2003 01:37
Seeing is believing...needed: video recorders w/e 1 & 2 soap108 General Forum 8 01-03-2003 21:51
CDI Jump Off Al Skierkiewicz Off-Season Events 0 07-10-2001 16:31
big jump, up to 131 Carolyn Duncan Chit-Chat 21 27-07-2001 17:54
