1) We take Kevin's encoder project from his website.
2) We remove the phase B logic. 3) We try to compile. 4) We get an error saying: Code:
\frc_encoder\frc_encoder\encoder.c:130:Error [1205] unknown member 'INT3IP' in '__tag_223' \frc_encoder\frc_encoder\encoder.c:130:Error [1131] type mismatch in assignment Code:
// interrupt 2 is low priority INTCON2bits.INT3IP = 0; If we remove the segment of code, the interrupt is always on high priority and messes other things up. We'd be very gracious for any solutions. |
Re: GTS Encoder Compilation Error
Seen it before. There's what appears to be a typo in one of the system's .h files, p18f8722.h. It may be in others as well, but I assume it's this one you're using. Just do a text search for INT3P and change it to INT3IP.
Don't forget to read the documentation, specifically step 9 of encoder_readme.txt.
Thank you very much, we did follow the readme, but we must have missed that. Our program now compiles without error. Thanks again.
Hey folks, looking for some help with a problem that has been posted about a few times already. It involves the typo in the p18f8722.h file.
I've gone in an edited the typo from INT3P to INT3IP in that .h file and I still receive this error: Code:
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F8722 "gear_tooth.c" -fo="gear_tooth.o" /i"C:\mcc18\h" -D_FRC_BOARD -D_LARGE_CODE -D_DONT_USE_TMR0 -mL -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa- \FrcCode_2007_8722\gear_tooth.c:71:Error [1205] unknown member 'INT3IP' in '__tag_248' \FrcCode_2007_8722\gear_tooth.c:71:Error [1131] type mismatch in assignment |
-Kevin |
#7
Yes. And then I edited the .h file and saw that it still had INT3P instead of INT3IP and I changed it manually and saved the file. I restarted MPLAB and recompiled and get that error every time.
#8
You should not have needed to edit the file, you probably recreated the problem when you edited it.
#9
I only edited it after testing it untouched and having it fail. Then I read the 5 or 6 posts about the issue and they all pointed to a very specific typo and to the best of my ability I found the problem and changed INT3P to INT3IP.
#10
Yes, this is a known bug in the provided mcc .h file.
I went through the same exercise and by changing the INT3P to INT3IP in mcc18/h/p18f8722.h it fixed the problem for me. Is there a local copy of the the include file in your project directory? Try renaming the mcc18/h/p18f8722.h file to h_ and try recompiling. If it doesn't complain about not being able to find the file, then it is using a copy from somewhere else. Also, make sure the error is the same. I had some code that referenced the field as INT3P and fixing the include file kick the error of not being able to find INT3P -- a quick look might mistake this for INT3IP. |
#11
Not sure what you mean in your second point. I opend the 8722.h file and searched for all INT3P and changed it to INT3IP but the error persists. |
| Encoder, GTS, Gyro, Camera != Work | purduephotog | Programming | 1 | 18-02-2007 17:20 |
| Encoder Error | Anime-niac_2.9 | Programming | 1 | 27-01-2007 16:23 |
| GTS Code Error (the red light of doom!) | Denz | Programming | 9 | 07-04-2006 17:39 |
| FIRST DVD Compilation | Mark McLeod | General Forum | 10 | 14-12-2005 02:02 |
