Go to Post Ancient doesn't necessarily mean bad, but ancient things do fall out of use, otherwise I'd be tapping this out in morse code or writing it in Latin. - Greg McKaskle [more]
Unread 16-03-2007, 21:29
Liborator Liborator is offline
FRC #2191
Liborator is an unknown quantity at this point
Smile Autodesk Downloads needed plz
Hi does anyone have on autodesk the 56mm Spur Gearbox, 2 motor adapter from BaneBots, the AM Servo Shifter (GEN 2), the AM Shifter (GEN 1),or the AM Gearbox (single speed), from Andy Mark? If so could they send me a link to download it, also does anyone have on Autodesk any univeral joints that can be used for drive shafts and 25 gage chain that i can download please send me a link i've searched everywhere on Cheifdelphi and only found links that no longer work :-/ please help thank you!
Unread 16-03-2007, 21:35
Gamer930's Avatar
Gamer930 Gamer930 is offline
Team 930 and 171 Alumni
AKA: Justin
Gamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to beholdGamer930 is a splendid one to behold
Re: Autodesk Downloads needed plz
The andymark products all have stp files of the parts on their website. www.andymark.biz under the product description
2010 to Present, Scorekeeper/Field Power Volunteer for FRC/FTC/FLL
2005 - 2010, Team 171 College Mentor
2002 - 2005, Team 930 Student
Unread 16-03-2007, 23:35
FRC #2191
ive seen that it says
"Downloads
CAD file (.stp)
AM Gearbox Assembly file (.pdf)"
but i have been unable to get anything to work or load onto autodest inventor
Unread 17-03-2007, 13:23
Dan Zollman's Avatar
Dan Zollman Dan Zollman is offline
7
FRC #1712 (Dawgma)
Dan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond reputeDan Zollman has a reputation beyond repute
"Downloads
CAD file (.stp)
Download the .stp file. Then open Inventor and go to File>Open. Choose STEP on the file type list and open the file you downloaded. Then you can use File>Save to save it as .ipt and .iam files.
When you open the assemblies from STEP files, the parts should be positioned correctly, but they will be uncontrained. You'll either have to constrain each one or Ground them to hold them in place.
Product design student at Rensselaer
Web designer/consultant
FIRST alum, Dawgma 1712
dan.zollman - at - gmail.com
Autodesk Inventor and downloads Erro Inventor 13 17-08-2006 19:25
**FIRST EMAIL**/Tell Autodesk What You Think! Take the Autodesk Survey AmyPrib FIRST E-Mail Blast Archive 2 12-06-2006 15:10
viz 2006 plant downloads trout2007 3D Animation and Competition 2 17-12-2005 08:11
Hex file downloads Ryan M. Control System 2 29-10-2005 19:50
Manual Downloads Chris_C General Forum 3 07-01-2002 02:46
