Robot doesn't turn in high gear
well i know that this has been posted before but i also know that other teams are having this problem and im sure they want all the info they can get. it seems that we are not getting the full potential out of our andy mark shifters not in low gear, low gear works great, but in high gear. we cannot turn in high gear, the battery voltage on the O/I drops and the motors seem to stall, we are using 1 big cim and 1 little cim on each gearbox any input????
would it be a smarter choice to switch to 2 small cims on each gearbox?? thanks |
Re: AM shifter problems
Andy B. |
Also it will help us help you if you give a complete description of your drivetrain/chassis....ratios, width, wheelbase, number of wheels, tread type, whether the center wheels are lower than the end wheels and by how much, etc.
Long, narrow, 4 wheel robots with sticky tread, and not much final drive reduction, just don't turn easily. Wide, short, 6 wheel bots with lowered center wheels, not so aggressive tread, and more final reduction turn just fine in high gear. |
(How to Be Sure Your Robot Will Turn)</edit> http://www.chiefdelphi.com/media/papers/1443 Last edited by kramarczyk : 02-04-2007 at 10:28. |
This is a classic symptom of too much friction in turns. As other have pointed out, your drivetrain and final gear ratio couple to produce near stall current on the drive motors. The small Chalupas stall at 129 amps while the larger ones stall at 96 amps. Add that up and you are likely drawing something in the neighborhood of 300+ amps even if your wheels are turning. With a fully charged battery with an internal resistance of .011 ohms, you are already dropping 3.3 volts at the battery, plus whatever series resistance you have in the wires. Remember that the RC will go to backup mode when the input voltage falls below 8 volts and all outputs are disabled. As you draw current from the battery, that voltage drop takes you seriously close to the magic 4 volt drop and RC shutdown.
#7
Re: Robot doesn't turn in high gear
its definatlly the fact that we have the 1 big and 1 small cim, were going to have to swap over to 2 small cims
thanks guys |
#8
How many teeth are on the sprocket on the wheel? How big are the wheels? |
#9
Im sure a big cim and small cim will work just fine, but i think the easiest fix would be to get some bigger sprockets on those wheels.
#10
I'm also inclined to pin it on a configuration issue along the lines of sanddrag's post, we can't be sure without getting more details (sprocket sizes, wheel coefficients of friction, etc.) without pictures (CD-Media is a wonderful thing) or more details. |
#11
I've seen their setup first hand. They have four 8"(?) custom traction wheels in back and 2 AM omni's in front. After watching them at Philly, their low gear was relatively fast, very similar to our speed, but we used the AM Single Speed Gearboxes on a 1 to 1 output to wheel ratio. So I would suggest that you increase the size of your sprockets on the wheels, decrease the size from the gearbox, or even both. That hopefully should help with the turning problem.
-Chuck |
#12
Team 418 used a 6 wheel drive, 4 small CIM-DeWalt transmission drive train. We lowered the center wheels 3/32", which is enough to sink the center wheels in the carpet, but still have all 6 wheels contact the ground. In 2nd gear we realized we had some difficulty turning (the RC was resetting, I believe), and after talking with the electronic guys we think we figured out why. When designing the drive train, I figured we could run each small CIM at 40 amps (since they are on a 40 amp breaker); however, I was informed that the power distribution block is rated for 85 amps (I'm not exactly sure, but around this number). This means we weren't getting the current, and thus the torque, we had planned on. Perhaps you guys are facing a similar problem.
#13
Ex. 4 ft #6 wire, breaker panel, one victor, 4ft of #12 from fuse panel to Victor to motor, 20 connections= (4x0.5)+1+4+8+20=35x0.1=3.5 volts drop in all losses at stall. This translates to a loss of about 1/3 of the available current or about a loss of almost 100 oz.in. of torque and a drastic change in the efficiency. |
#14
As for the resistance in the circuitry, we kept the wire lengths to a minimum, and will definitely be more conscious of it in the future; however, I do not understand how this would fully explain our problem. At 40 amps, a small CIM outputs ~.8 N*m (please correct me if my calculations are wrong), and IF we could run them significantly beyond this, say, near stall current, then even if you take the ~2.2 N*m stall current then the wire resistance would have to be somewhere around 76 WF. Though I am not the most familiar with our electronics system, I am confident it does not have this much resistance. Now, I did make several assumptions when calculating the torque needed to turn in 2nd gear, so in actuality .8 N*m of torque might not have been enough; but, assuming that the difference is negligible, how do you explain the problems we faced? Also, I have just talked to our electronics/code mentor and he suggested that we bypass the Rockwell block to see if it is (at least in part) the problem. He also suggested we monitor the voltage on both sides of the Rockwell block using a USB DAQ, so when we get those results I will make sure to follow up on this. |
#15
what happens with electrical parts when a lot of current goes thru them, is that they get hot....every part has resistance, and resistance turns electrical power into heat energy. When the metal parts get hot enough, they melt thru and can no longer conduct electricity. The point of having circuit breakers and fuses, is to put a "weak link" in the circuit that will fail first, and prevent the other wiring and components from overheating. The power distribution system for the robots is a well designed system, and will do it's job if you follow the instructions carefully so you build it as designed (and make sure to tighten all the wire connections firmly) |
| How to turn down gear hubs? | sanddrag | Technical Discussion | 12 | 20-01-2004 09:10 |
| motor high gear/low gear switch... | archiver | 2001 | 6 | 23-06-2002 23:50 |
| low gear vs high gear | archiver | 2000 | 1 | 23-06-2002 23:07 |
| Robot Turn-in | Mike Martus | Off-Season Events | 0 | 08-11-2001 19:32 |
| Gear Ratio Doesn't Matter | Paul Copioli | Technical Discussion | 2 | 27-09-2001 08:18 |
