Go to Post When FIRST teams are as numerous and as well supported as basketball teams, we will know that our culture is preparing young people to compete in the 21 st century and we are spending our 2 million minutes wisely. - N7UJJ [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 02-04-2007, 22:33
The GarbageMan's Avatar
The GarbageMan The GarbageMan is offline
FRC #0545
The GarbageMan will become famous soon enough
What are the best wheels to use on carpet?
My team has had major problems with our wheels this year. We are using 4 wheel drive, skid steering with the wheels that came in the kit of parts and we can not turn the robot on the carpet. We are now going to the nations and I want to buy new wheels that sovle that problem. Does any one know what wheels go best on carpet?
Thanks
Unread 02-04-2007, 22:35
Re: What are the best wheels to use on carpet?
Take a look at some of these threads. Feel free to play around with the search feature until you find what you need.
http://www.chiefdelphi.com/forums/se...earchid=861333
Good luck!
Unread 02-04-2007, 22:36
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Buy some AndyMark molded omni wheels for the front and your good-to-go!
Unread 02-04-2007, 23:25
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
There is no "best wheels" There are a lot of other factors. What you are experiencing is too long of a wheelbase, too narrow of a track width, too much traction, or any combination of the above. Many teams use 6 wheels, with the center ones lower, so only 2 or 4 can be on the ground at a time. Some teams use omni wheels on one end. Some teams use high traction wheels and low traction wheels. Watch some robots, see if you like how they drive, then find out why they drive so nicely. There is no clean and simple best.
Unread 02-04-2007, 23:30
Bharat Nain's Avatar
I have to agree. There is no "best wheel", but there are better wheels than those in the kit of parts. It all depends on what you are trying to achieve. If you want you robot to be very maneuverable, using a combination of omni-wheels will help. For traction, the IFI traction wheels are good. We have had success with Skyway Bead-Lok wheels by custom cutting them. Another factor is the setup of your chassis. 4 wheel or six wheel - middle wheel lowered or kept at the same height. These are all decisions you need to make depending on what your objective is. If you are at the championship, I would suggest you check out different drive bases teams have built. By talking to them, you can learn a whole lot of principles and concepts they used. Additionally, check out all the pictures and threads about robots on CD. There are also many white papers written on building a successful drive base. Good luck.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 03-04-2007, 00:39
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Very true. It all depends on the style of steering on which wheels you should use. We use 4inch high traction, but they go through about a 9:1 reduction from the CIM motors driving them and we use a coordinated steering on top of an electronic differential to minimize slippage. Maybe you could try using traction wheels on one end and omnis on the other? We have never really used skid so I dont know what will work the best. I think with the 2 and 2 you can get traction along with manuverability because of the omnis, but I dont know.
Good luck
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 03-04-2007, 01:15
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Since the question is "best on carpet", my answer would be 1" IFI wheels with natural rubber tread. These seem to offer the best combination of weight, traction, durability, and price. Anything wider than 1" and turning suffers.
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 09-04-2007, 18:30
John Gutmann John Gutmann is offline
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
John Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant futureJohn Gutmann has a brilliant future
Send a message via AIM to John Gutmann Send a message via MSN to John Gutmann Send a message via Yahoo to John Gutmann
1" Diameter Wheels!?!?!?
Unread 09-04-2007, 18:53
Gabe's Avatar
You know what I mean... 1" wide wheels!
Unread 09-04-2007, 20:29
I'm right here
AKA: sparksandtabs
FRC #0340 (GRR)
I knew what you mean, I just thought I would screw with you a little.
Unread 03-04-2007, 06:46
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Thanks
You are looking for this white paper... "Drivetrain Basics (How to Be Sure Your Robot Will Turn)" - by Chris Hibner
http://www.chiefdelphi.com/media/papers/1443
I laid out a spreadsheet to do the math and allow you to plug in different wheels for both front and rear.
http://www.chiefdelphi.com/media/papers/1917
Mark
Brick walls are for other people. - Randy Pausch
What kind of wheels do you use? Cpt_Dave_Lister Kit & Additional Hardware 30 17-10-2005 22:28
What kind of materials do you use for your wheels? Alex Cormier Technical Discussion 1 24-01-2005 19:19
What are the restrictions regarding the wheels Dom Ruggieri Technical Discussion 5 11-01-2005 08:45
what are some good strategies to use this year ewankoff Scouting 8 04-01-2005 22:36
What do you use for wheels? Andrew Technical Discussion 36 08-01-2004 10:20
