Go to Post I just want to see Aerial Assist again. Played on Lunacy regolith. With minibot poles. Which are on coopertition bridges. Is that too much to ask for? ;) - M. Lillis [more]
Unread 15-04-2007, 22:01
D.Fahringer's Avatar
D.Fahringer D.Fahringer is offline
Engineering Tech
FRC #0122 (NASA Knights)
D.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of lightD.Fahringer is a glorious beacon of light
pic: Team 122's Omni-Wheels
Unread 15-04-2007, 22:02
zander_108's Avatar
zander_108 zander_108 is offline
AKA: Zander Guerra
FRC #0108 (Sigmac@t)
zander_108 will become famous soon enoughzander_108 will become famous soon enough
Send a message via ICQ to zander_108 Send a message via AIM to zander_108
Re: pic: Team 122's Omni-Wheels
obviously the entire rims are actually 2 pieces and they bolt together..
Unread 15-04-2007, 23:59
Engineering Tech
No, they are one piece... It goes together like a puzzle... the omni wheel is built with close fitting Lexan ribbed rollers, using eight axle shafts with 16 circlips to capture the rollers. That was the 2002 8 inch diameter version of the 6 inch diameter 2001 omni wheel. The trick to assemble and take apart my design has been explained to a number of FIRST students and mentors at the events we (122 NASA Knights) attended then at VCU, Phillidelphia, and Orlando. Can you figure it out now? I used solid axles, and I will say that even if all the retaining clips on the axles came off the rollers never could, So the waterjetted wheel frame is in fact One Piece! ... with eight inline axle holes. This wheel got great grip, the ribs would cog into the pile of the carpet.
I will place more pictures to follow up .....I will look in my archive for them soon.
Thanks!
Dave F.
Friction coefficients for Omni wheels and Mecanum wheels from AndyMark Andy Baker Technical Discussion 11 16-12-2006 19:40
pic: omni wheels CD47-Bot Robot Showcase 15 03-03-2004 20:10
pic: #1018's omni wheels CD47-Bot Robot Showcase 22 19-02-2004 15:04
Omni Wheels edomus General Forum 6 06-02-2004 13:35
Omni Wheels! jrgrim12 Technical Discussion 5 04-02-2003 16:07
