Microsoft's dominating power
Look this is not an OS better than you are thing. This is just an article for webmasters on how this might affect them. It seems like Microsoft is monopolizing once again by getting rid of key Netscape Components, making Netscape harder to survive.
http://aolpf5.marketwatch.com/news/s...-5A23D5072DEE} |
Re: Microsoft's dominating power
It appears that up until Internet Explorer 5.5, IE supported plugins that were actually written for Netscape and included with the EMBED tag. I was unable to find a press release at Microsoft's web site regarding this change, but it appears that they had security issues with the EMBED tag, and therefore dropped support for it in favor of the ActiveX control's OBJECT tag that they have included with Internet Explorer since about version 3.0. Because of this change, viewer plugins that were written using the Netscape plugin format, and therefore worked because of IE including support for that format, no longer function correctly. So, Apple has released an ActiveX wrapper OCX for the QuickTime player. Based on my own experiences, it seems that Apple was behind the times in doing this. I know that other popular plugins, such as Flash, already had an OCX format for Internet Explorer. It seems that Apple was trying to get away with only having to write one plugin that would work everywhere for as long as possible, and they have only now run out of time. Here's that page I found... http://www.apple.com/quicktime/produ...s/activex.html |
no way am i surprised. bill gates is just a business man trying to make a little cash money. like he needs it.
/edit he can also get office 2000 for an unbelevablly cheap price. i think it's usually in the hundredes of dollars range, but he can get it for $10. ![]() Last edited by David Kelly : 27-08-2001 at 21:33. |
#9
$200
Oh my god I didn't think Windows was that expensive
http://www.amazon.com/exec/obidos/AS...525429-4856141 But it is true, $200 for just an upgrade. I thought Mac OS X was expensive at $129 (Full version). I remember a couple of years ago that Winodows 95 or 98 was $99 full and $49 upgrade. I have heard of educational versions of software of 50% to 70% off, but not $5. Must be some lincening argrement. |
#10
Re: $200
This I think will kill Microsoft in the future with the courts by using more Monlipizing power Oh course I think people will create hacks to solve this problem. But to the common user of a computer, they will have to shell out a lot of dollors for Microsoft being Gready. Becuase they thing they can what they want, whenever they want, and people are powerless to stop them. The cost for the Wintel PC may go up becuase of Microsoft's strict lincencing. But I just taking a guess on that. I have no knowledge that it will. Anothering thing that is currious. Windows XP went gold last week, but PC's won't be installing them for 2 months fom now. Does anybody know why? |
#12
All non-free software has virtually the same license agreement, Microsoft is just enforcing it. If you don't like it, don't buy it ![]() Last edited by Joe Ross : 28-08-2001 at 00:32. |
#13
And now, I get to once again casually mention that Microsoft Works is the ultimate oxymoron. ![]() |
#14
I wouldn't have a problem with it if micosoft didn't charge so much for windows.
#15
The Windows Product Authorization (WPA) system takes the product key that you enter during installation and combines it with a hash key generated based on certain parts of your computer's hardware. For those not familiar with a hash key, when fed the same information, it will always generate the same result, however, that result cannot be reversed to determine what was fed into the algorithim. Within a set period of time(currently 14 days in RC2, may change for release version,) you are required to submit the 50-digit code that your computer gives you to Microsoft in one of two ways: -Internet -1-800 telephone call When Microsoft recieves this code from your computer through whatever means you choose, they verify that the product ID portion of the authorization code is not already on file as being matched up with a different hardware hash key. After this is verified, they return to your computer a code that notifies Windows(or Office XP, which uses the same system) that it is properly authorized. At that time, your system no longer has a time limitation. Note that this authorization process and the registration process, where you supply your personal information, are completely separate from each other. It is possible to authorize the software without ever registering it, and therefore your personal information has no way of being included in the authorization process. The requirement that this needs to be done is made very clear during the installation process, and it DOES require user intervention to start the authorization process, so you are aware that it is taking place. When you use the Windows Update system to check for updates to your computer, the hardware hash code is re-generated and sent to the Windows Update server at Microsoft. In the event that the code does not match the one previously on file for that Product Key, the software goes into a "limited-use" mode, which in the case of Office XP, means that no files can be saved or edited. However, existing files can still be opened and viewed. At least, this is my understanding on the matter, I don't have Office XP personally to verify this on. If you still legitimately have a license for the software(i.e. you overhauled the majority of your computer,) you can contact Microsoft and they will issue a new authorization code which will allow the software to function normally again. However, you are not required to keep some form of Internet access on your machine, nor are you required to even use the Internet for the initial authorization. Also, it is my understanding that in the event of a software package going into "limited-use" mode, it will not be your machine(the one that the software was FIRST authorized on,) but rather any other machines that you installed and attempted authorization on AFTER authorizing it on your own machine. |
| Types of Drives? | indieFan | Technical Discussion | 50 | 20-10-2003 12:27 |
| power to the pits | Ken Leung | Off-Season Events | 12 | 11-05-2003 22:48 |
| URGENT!! Need OI power brick specs for 7AM demo tomorrow!!! | kmcclary | Electrical | 8 | 10-10-2002 10:56 |
| power of globe motor with gear box? | Ken Leung | Motors | 5 | 21-11-2001 13:43 |
| Max mechanical power of motors, how is it useful? | Ken Leung | Motors | 1 | 09-11-2001 14:15 |
