The best multi-speed transmission
AndyMark's transmission is alright, but I've seen many that are just as good and much lighter. What do you guys think is the best multi-speed transmission that are also light and durable?
Re: The best multi-speed transmission
you're own custom gear box. whatever your heart desires and your machining capabilities. you can build the best one ever. It doesn't matter who's is best. I see if you made one and it works on the bot and is effective you have reached your goal.
other then that general stuff, i do love the orginal 33 4 speed auto which 1126 has adapted for the last 3 years. |
The 254/968 transmission was quite impressive this year, weighing in at a shocking 1.3 lb.s. It was obviously lighter than virtually any other shifting transmission (and most single speed) in FIRST, could take input from 1 or 2 small CIM motors, and worked without a hitch.
The AndyMark's are fantastic for their reliability, ease of assembly, flexibility (can take 1 or 2 small CIMs, Large CIM, or even a FP through an AM planetary), low weight and cost, and durability. They have several areas teams can lighten them even more will little trouble (namely the cluster gears and mounting plates). |
Could you guys be so kind as to show me photos and purchase information to the transmission that you think is great?
Dewalt transmissions are an awesome choice. Under 100 dollars for a three speed shift on the fly transmission; you really can't beat that anywhere else.
Joe P.'s White paper should explain everything you need to know. |
#7
254/968's are great. Looked at them in the pit, and I could barely feel the weight of them. On superficial inspection they also seemed really efficient for a direct drive setup. AM's are good also, just make lighter side plates..
#8
254's are custom built using some pretty exotic techniques. I could be mistaken but I heard that they are planning on using Andymark gears next year to make them easier to build which will in turn make them heavier. I did look at them in the pits and they were absolutely amazing.
#9
I had a chance to look at the cheesy poof transmissions in Atlanta, they had a display with all the parts sitting there. The parts look familiar somehow...sort of like the parts in an AM shifter, only lighter. They are beautiful!
I still haven't figured out what the advantages are to having a lightweight drive transmission, though. |
#10
More weight to use elsewhere. This year the poofs really didn't need it (weighing in a stunning 86 lb.s before adding the ramps), but many other teams would have like the extra couple pounds to play with.
#11
I can understand making a manipulator transmission as light as possible. The problem I see with a light drive transmission, is that the saved weight might be put higher up on the robot...resulting in a tippy bot.
Wheels, frame, and drivetrain is where you want the weight to be. |
#12
I think that the best multi-speed up to this point in terms of sheer engineering is that 254/968 gearbox they have been flaunting around at all the regionals my team has attended. The gears are astonishingly light. 1.3 lbs a gearbox made my jaw drop the first time I had the whole thing handed to me. It really is hard to argue against the sheer awesomeness that is that gearbox, really makes me want to one-up them and make something 1.299 lbs!
-Guy |
#13
For the past two years Team #39 has tried to use the transmissions that come with the KOP. We felt it would be easier to help rookie teams if we had to overcome the same problems they had. After the Banebot problems this year we do not want to use them next year. My question is, do you think the KOP will have the Banebot transmissions next year? If they do, I think we will return to the AM trany.
Ken |
#14
#15
Yep. Exactly.
| Possible to do multi-speed transmission with v-belt? | Squirrelrock | Motors | 15 | 13-12-2005 14:44 |
| Multi-Speed motor Questions | Burg | Robotics Education and Curriculum | 2 | 23-12-2004 15:54 |
| The perfect 2 speed Transmission..... features... | Salik Syed | Technical Discussion | 28 | 20-10-2004 11:44 |
| White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission | CD47-Bot | Extra Discussion | 4 | 14-07-2004 15:43 |
| Multi-Motor/Transmission justification | Gui Cavalcanti | Technical Discussion | 2 | 22-02-2004 17:15 |
