Piranha 36:1 Gearbox for FP?
I ran across a "new" gearbox today that might be useful for the Fisher Price motors. It looks like a 36:1 planetary designed to mate directly with the 550 can motors so it should be a snap to fit to the Fisher Price motors. It has a 1/2" keyed output shaft and looks pretty easy to mount as well. They are ~$94 each but I am wondering about the quality and reliability as compared to the Banebots.
Has anyone seen/used one of these? http://www.partsforrobots.com/Produc...ha/piranha.htm and http://www.robotcombat.com/marketpla...anhamotor.html |
Re: Piranha 36:1 Gearbox for FP?
Testing would probably have to be done on these. The site says that they are designed for use in 12-15 lb robots, while ours are 100-150 lbs. It wouldn't be ideal for drive. Other than that though, its output shaft speed is in a pretty good range. With a 6" wheel, its freeload speed is 11.4 fps. For an arm or manipulator though it could be implemented.
12-15 pounds would still work for an arm or some other type of a manipulator.
| Offseason gearbox project... maybe this gearbox has helical gears? | Travis Covington | Technical Discussion | 17 | 05-06-2006 11:48 |
| Adapter for FP gearbox | Nitroxextreme | Motors | 1 | 28-01-2006 17:36 |
| request for info on gearbox gears | jskene | Technical Discussion | 0 | 08-01-2005 18:07 |
| gearbox for atwood motors | DaveG702 | Motors | 3 | 17-12-2002 10:30 |
| Specs for drill motor gearbox? | archiver | 2000 | 4 | 23-06-2002 22:36 |
