Go to Post If Amanda is 'old', I am beginning to feel like a fossil.... - Chris Fultz [more]
Unread 22-04-2007, 22:54
Alex.Norton's Avatar
Alex.Norton Alex.Norton is offline
Fidgetting
Alex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud ofAlex.Norton has much to be proud of
Send a message via AIM to Alex.Norton Send a message via MSN to Alex.Norton
pic: All Terain Swerve 2
Unread 22-04-2007, 23:01
Tytus Gerrish's Avatar
Tytus Gerrish Tytus Gerrish is offline
IGAB, ADHD, and Dislexic
AKA: Ty
FRC #0179 (SwampThing)
Team Role: Tactician
Tytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond reputeTytus Gerrish has a reputation beyond repute
Re: pic: All Terain Swerve 2
i had this very idea before and constructed a few working lego models of it. i found that the treads needed a boogie wheel to function as a swerve unit. The tagging function was not aserted at the time i uploaded it. keep it up its cool
EDIT: here it is http://www.chiefdelphi.com/media/photos/18460
Unread 22-04-2007, 23:02
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
what sort of motor will you use to turn the module? with that much scrub, it may require a bit more power than a traditional swerve.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 22-04-2007, 23:25
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
How do you plan on insuring the tread stay on the wheels? With that long of constant contact on a flat surface, turing the modules would likely knock off the treads.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 22-04-2007, 23:49
Fidgetting
the treads would stay on with a groove in the middle but the modules would only turn when the robot was moving so this would hopefully not be much of a problem. I would be using a fisher price to turn the module through a 42mm 256:1 banebot gearbox.
The reason that I don't want to use a third roller to reduce turning force is because the module passively rotates on one of two axes. If there was a third wheel then it wouldn't be stable and there wouldn't be as much surface area on the ground and the point force is higher. Since this would be for an all terrain robot this would be detrimental to moving through things like mud. I know that the gears need more protection for things like that.
Thanks for the thoughts and that lego bot is sweet
Unread 23-04-2007, 18:10
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Nice, I like the design... I am working on something also, just as a prototype that I think will be pretty sweet. All I need is a real tank, about $500,000.00 and a couple ounces of plutonium, some nuclear scientists, and an orange. Hopefully I can find a sponsor that will hook me up.... oh... Is it against the rules to have a nuclear reactor as a power supply in FRC?
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 23-04-2007, 19:17
AKA: Ty
if your looking for 'all terrain' in the real world it means things like mud sand and snow. all deformable surfaces where having a ferfectly flat tread on the deformed surface produces no advantage. a tread in a crab module in a deformable surface becomes like a spoon mixing batter and on a non deformable surface like concrete it acts like an anchor. a tremendous resistance to rotation . and ut this on a first carpet it becomes a machine that is only sterable while its moving. negating the advantage of a swerve drive in the first place. your design and drawings are cool but their only that at this point. practacalty needs to superseed awesome models and drawings
Unread 23-04-2007, 20:45
Tapoore's Avatar
Tapoore Tapoore is offline
AKA: Tom Poore
FRC #1519 (Mechanical Mayhem)
Tapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of lightTapoore is a glorious beacon of light
Take a look at this. One of my teammates works at MobileRobots, the company who builds these things ,so I have got a chance to see one of these crab-steering beasts. They are huge! They're designed for patrolling perimeters and for surveillance.
- www.mechanicalmayhem.org -
* 2015 Granite State District Event Champions
* 2013 Einstein Finalists
* 2006, 2010, 2011 Granite State Regional Champions, 2009 Chairman's Award
* 2012, 2013 North Carolina Champions
Unread 23-04-2007, 21:57
AdamHeard's Avatar
Lead Mentor
You should do the math to see if the modules can even be rotated by the FP.
pic: All Terrain Swerve 1 Alex.Norton Extra Discussion 17 23-04-2007 18:11
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
pic: Swerve! =Martin=Taylor= Extra Discussion 15 07-07-2006 01:58
pic: Swerve Assembly CD47-Bot Extra Discussion 3 23-01-2004 20:02
