TTL serial max power
ok Im working on something and I need to know how much power the TTL serial port can put out. basicly the question is weather or not I can run several (2+) microchips off of that +5v. but if I could get a # that would be great.
Re: TTL serial max power
I think the 5v on the RC can supply 1 amp, that is shared by all of the devices in or plugged in to the RC.
awesome!
Yea but that doesn't mean you can safely pull an 1 amp through the chip. if the TTL serial port is connected to the uC then you can only source ( or sink ) as much current as a general IO pin because that is basically what the pin is.
-John |
I wouldn't worry too much about the safety of this....
For instance, if you short out a +5v pin and a gnd pin on a Digital I/O (for example), all that happens is the RC Hardware light comes on. It doesn't break anything. It just won't work. My 2 cents. Jacob |
no I was just looking for an answer over 100ma. I dont plan on running close to an amp.
#7
If you look in the data sheet look at the max sink/source per I/O and that is your answer.
-John |
#8
I think he is talking about the +5V that is available on that pin, not the actual TTL lines themselves. That +5V pin is tied directly into the 1A 5V bus in the RC.
| Noisy power supply interfers with rs232/ttl | Mike Mahar | Programming | 1 | 27-01-2007 22:02 |
| 2004 Edubot Serial String Help (TTL in) | Josh Siegel | Programming | 6 | 10-12-2006 08:28 |
| TTL port to a serial port on a demo board | ImmortalAres | Programming | 16 | 09-07-2005 23:44 |
| TTL Serial Port and PS2 Mouse Interface | cbolin | Electrical | 8 | 29-12-2004 15:00 |
| Max mechanical power of motors, how is it useful? | Ken Leung | Motors | 1 | 09-11-2001 14:15 |
