innovation first breaker panel
does any one know what the pwm plug and serial ports are for
if you want to know why I'm using it on a demo bot |
Re: innovation first breaker panel
You can get info from the IFI page: http://ifirobotics.com/circuit-breaker-panel.shtml
And their reference guide: http://ifirobotics.com/docs/breaker-...005-revnc0.pdf It mentions the serial connection, but doesn't say anything abut the PWM connection. |
I believe the PWM port is actually a serial port, I may be wrong. The serial port is used to send info about which breakers are tripped to the RC. The default MPLab code already has support for that data.
It has two serial port interfaces, but only one serial device.
The Standard DB-9 port and the PWM port TX, RX, GND. Of course IFI says you shouldn't use the PWM connector. They didn't say you can't however. http://www.ifirobotics.com/forum/viewtopic.php?t=165 The serial port is used to send info about which breakers are tripped to the RC. The default MPLab code already has support for that data. |
| Innovation First Breaker Panel | falconmaster | Electrical | 3 | 25-08-2006 13:51 |
| Breaker Panel Diagnostics | dm0ney | Programming | 4 | 29-03-2005 19:00 |
| Bad Breaker Panel? | jdiwnab | Electrical | 5 | 14-02-2005 14:45 |
| Digital Breaker Panel | Mark McLeod | Control System | 8 | 31-01-2005 00:22 |
| Breaker Panel | Gal Longin | Electrical | 1 | 13-01-2005 16:01 |
