pic: Planitary Transmission
Re: pic: Planitary Transmission
It looks great.
Can you give us some more details about it? Sizes, Forces etc.. |
looks like it could be a great transmission if it is geared to the wheels correctly. love the design, great work man.
It's true that the ND motor cannot be backdriven, but you may face another problem. The gear inside the ND is plastic and in high-torque applications (such as a drivetrain) it has been known to strip. I don't know what forces you're putting on it, or exactly what would be enough to destroy the motor, but be careful. Prolonged use, even below the actual stall torque of the motor, can wear down that gear.
Is there any chance you could explode this assembly or provide some better explanation of what it does?
I'm curious as to how you plan on attaching that back plate to the motors...
Other than that, looks like a solid starting base! |
#7
Back plate looks easy, probably just some holes for the super long screws that hold the CIMs together. Dunno if that's legal or not but that's how I'd do it. I'd be more concerned about the planetary assembly itself. With all the elements on bearings, I think you'd need to plan for a little more backlash than usual to account for extra play from the bearings.
#8
Re: pic: Planetary Transmission
I like the idea, but I would never put the Denso motors in a drivetrain. Even though the worm inside the motor is metal, the gear is fairly soft plastic and strips way too easily.
If you want to make your tranny anti-backdriveable (sp?), I would recommend that using a wormgear other than the one in the Denso. |
#9
Love the work and wish I had some ability to design drive-train transmissions. |
#10
I believe that the denso worm gear would see relatively little torque because it is just modifying one part of the planetary gear train that is normally stationary. Precession and procession modify the gear ratio. Can you show the exploded view of the planetaries?
#11
I GET IT!!
I have been looking to do the same thing for a while. Its sort of a constant velocity transmission. But teh Denso motor won't really allow uch variation. Consider this. Use to motors, on on the hub and one driving the outer ring. I agree that you will have to put some current thru the outer ring when running just the hub but the payoff is many different ratios Nice cad work |
#12
Out of curiosity, where are you getting the combined spur/ring gear?
#15
I have taken a CIM apart on many occasions in the past to do many things to them (turning the shaft down to mate a pinion gear during the off season) and while the turning the shaft down destroyed the motor getting the bolts back in was extremely easy. It also happens that on our robot this year we had a big CIM that could only be taken out by taking the motor apart (it wasn't a bad design, it was my incompitent machining) and that big CIM still works like a dream. Quote:
On a similar note if anybody knows where to get a 20DP, 40 tooth ring gear that would help imensly cause mcmaster doesn't seem to have ring gears and stock drive products doesn't have 20DP gears. Thanks |
| pic: 379's transmission | Robo_Cat_379 | Extra Discussion | 10 | 05-03-2007 08:48 |
| pic: 2 Speed Transmission | AustinSchuh | Extra Discussion | 20 | 30-12-2006 16:39 |
| pic: 2 speed transmission 1 | psyco_klown | Extra Discussion | 3 | 05-09-2006 19:03 |
| pic: 2 speed transmission 2 | psyco_klown | Extra Discussion | 0 | 22-05-2006 13:35 |
| pic: lego Planitary... Kinda | CD47-Bot | Extra Discussion | 5 | 14-07-2003 23:55 |
