Go to Post I think it's important to keep FIRST's most important award as the top point getter [in Fantasy FIRST]. It's help reinforce that the Chairman's award, Engineering Inspiration and Woodie Flowers award are actually important and FIRST is about more than just the robots. - Koko Ed [more]
Go Back   Chief Delphi > Other > Math and Science > NASA Discussion
Unread 20-07-2007, 22:21
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Mars dust storms suck life out of rovers
From MSNBC
A raging dust storm on Mars has cut power to Nasa's twin rovers to dangerously low levels, threatening an end to the mission.
What a ride it has been. I hope this is not the end for these remarkable machines.
Unread 22-07-2007, 21:02
Andrew Schuetze's Avatar
Andrew Schuetze Andrew Schuetze is offline
499 Founder / Alamo FTC & FLL AP
Andrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond reputeAndrew Schuetze has a reputation beyond repute
Re: Mars dust storms suck life out of rovers
Here is a nice Quicktime movie from NASA describing the situation for Opportunity. More information and other movie options can be found on this NASA page.
APS
Founder FRC 499
Parent alumni FRC 2745 & 4219
Co-Coach FTC 4549 & 6407
Alamo FTC Affiliate Partner
Alamo FLL Affiliate Partner
Unread 22-07-2007, 21:14
JBotAlan's Avatar
JBotAlan JBotAlan is offline
Forever chasing the 'bot around
AKA: Jacob Rau
FRC #5263
JBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond reputeJBotAlan has a reputation beyond repute
Send a message via AIM to JBotAlan Send a message via Yahoo to JBotAlan
So I have to wonder, what does the rover need to maintain? I've never built a rover and sent it to Mars ( ), so I obviously am not familiar with the intricacies of such, but I am just purely curious; why not just cut the power for a period of time?
That's crazy that they have lasted so long, though.
Aren't signatures a bit outdated?
Unread 22-07-2007, 21:19
From what I've read, the nights are sooo very COLD that the electronics must be kept warm or else they won't survive. So if the Rovers cease to recieve enough solar energy to power their electronics heaters, they will Freeze over. Appearently, it can get cold enough that contraction of the different metals at solder points will crack and lose connection. There also has to be enough power to keep the basic operating system running or what would tell it to wake up?
Others more knowledgable folks can provide more specific information or correct any of my mistakes
APS
Founder FRC 499
Unread 22-07-2007, 21:42
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I imagine that it also gets cold enough to freeze the electrolyte in the Li-ion batteries unless they have some very specialized formulations and engineering compromises to prevent freezing damage.
Unread 23-07-2007, 00:21
Andy A. Andy A. is offline
Getting old
FRC #0095
You're correct- The main concern is keeping the rovers warm. I couldn't say what the power requirements are for that but it sounds like there is a shortfall, and the temperature is falling below acceptable limits at night. The rovers computer and at least one transmitter also have to operate in order to make contact with Earth and do stuff like run heaters, charge batteries and such. Maybe Dave L. can chime in with some inside info.
I wonder if some instruments like the camera mast and arm, that are not in the central 'warm box', are also heated. If so, at what point do ground controllers decide not to heat instruments in order to save core functions like communications? Is it worth having a rover with no arm? One that can't drive?
Unread 23-07-2007, 01:16
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
With any luck, the storm will clear enough to let sufficient light get to the rovers' solar arrays. But if this storm does bring their extensive career on Mars to retirement, then I think it would be a proper goal for us to retrieve one (or both) of the rovers when humans finally go to Mars for preservation and display in the Smithsonian. They've worked too hard over there on Mars to just be left there forever.
Art Dutra IV
世上无难事,只怕有心人.
Unread 22-07-2007, 21:17
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
Hopefully they will pull through but if they don't then they don't owe NASA anything. Running over 2.5 years longer than they were ever designed NASA has gotten thier money's worth from them and should be models for the engineers who designed them when they design the next machines knowing what design and parts have worked well. They were also a nice boost for NASA in light of previous craft failure.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 23-07-2007, 20:00
DonRotolo's Avatar
Back to humble
FRC #0832
Maybe I'm too old, but I volunteer to go out and get one of them. (I might need to borrow a hand truck, though)
Don
Unread 24-07-2007, 11:56
Blue Shirt
FRC #0237
From MSNBC
"Both came through the weekend beautifully," Squyres said in a telephone interview. "They were both power positive over the weekend, meaning they were generating more power than they were consuming."
Unread 24-07-2007, 12:01
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Great news! Does this mean they will be fully functional again and providing more insight to Mars soon?
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 24-07-2007, 13:48
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Did you read something that I didn't? I saw reports that battery energy was getting low, but nothing to indicate that less that full functionality.
Richard Wallace
since 2003
Unread 24-07-2007, 14:08
Go VOLS!!
AKA: Budda648
no team (QC Elite)
I guess I was under the impression that because of the storm, they had to shut down much of everything. There was a chance they wouldn't have been functional afterwards, right?
Do The Tyler!
Unread 24-07-2007, 14:40
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Even if the storm does settle, wouldn't the dust settle on the solar panels thus rendering them useless?
I win! XD
Unread 24-07-2007, 14:45
Go VOLS!!
AKA: Budda648
no team (QC Elite)
I'm not sure that it would settle enough to stay on the solar panels. Isn't there a constant wind on Mars? Is there enough to keep the panels clean and dust free?
Do The Tyler!
Mars rovers raring to go on new adventures JohnBoucher NASA Discussion 0 28-12-2006 21:19
Mars Rovers Update JohnBoucher NASA Discussion 12 31-05-2006 20:42
Mars Rovers on Red vs. Blue Kevin Kolodziej Chit-Chat 1 06-02-2004 06:27
Students - Name The Mars Rovers!!! dlavery NASA Discussion 17 28-12-2002 16:44
Twin Rovers going to Mars...hmmm archiver 2001 2 24-06-2002 00:51
