Go to Post First and foremost, teach which end is the hot one on a soldering iron. - Al Skierkiewicz [more]
Unread 22-08-2007, 13:48
chris31 chris31 is offline
Team 2021 Captain
AKA: Chris Davidson
FRC #2021 (FA Robotics)
chris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond reputechris31 has a reputation beyond repute
Send a message via AIM to chris31
MIT/FIRST DIY Segway
Congratz to the guys who were working on the DIY segway as a summer project. You are on Engadget and now the front page of digg with 282 diggs.
http://www.engadget.com/2007/08/21/c...po-diy-segway/
http://digg.com/mods/Clever_students...apo_DIY_Segway
Unread 22-08-2007, 19:03
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Re: MIT/FIRST DIY Segway
Thanks. And thanks to these guys:
http://www.waylandfirst.com/albums/a...rs/img-84.html
http://www.waylandfirst.com/albums/a...rs/img-81.html
(Ignore the "we'll own them" caption... They were feeling a bit competitive, I guess, being down in Atlanta and all.)
Whatever you told our HS students down in Atlanta convinced them that they should convince me to let them make a Segway. So this is your project, and for that matter all of CD's and FIRST's project, too!
-Shane
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 22-08-2007, 21:45
What was the hardest part about building your segway? Was it more of a programming project or mechanical? I figured that the harder part would be programming the controls and functions of the gyros. I was just curious. Awesome job btw.
Unread 23-08-2007, 00:33
dtengineering's Avatar
AKA: Jason Brett
I can see some awards being handed out to the first team to show up with a seg-bot at a Regional. Not to take anything away from this awesome project, but from watching the video, it really makes me appreciate just how smooth the real Segway really is. It will be interesting to see how close the DIY one gets... is it just a matter of tweaking the control loops?
Jason
Unread 23-08-2007, 01:17
FRC #0701 (RoboVikes)
Pretty cool, although I saw the same thing a few years back... did you totally design from scratch, and did you use only first parts?
Team 701
Unread 23-08-2007, 11:52
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I'm amazed they got enough power at a reasonable current with 12volts... I think the segway runs like 48 or 96 volts to cut down on current/wiring weight.
Anyone know what motors they used? PWM drives? (Being MIT, they probably put their own FET bridges together)
As a note... i'm not sure you could build this with the current FRC control system... the 120Hz max chop rate on the victors would probably make your servoing relatively rough (Segway probably has an update/chop rate of several KHz)
Amazing project... now if I could just pitch having to build one to my boss so I had the funds....
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 23-08-2007, 12:11
Team 2021 Captain
AKA: Chris Davidson
-q
They used the small CIMs with the Banebots gearbox and I believe they used Victors. I think they have all of the information on ther epage I just have to go back and read it all.
Unread 24-08-2007, 00:09
ZZII 527's Avatar
AKA: Shane Colton
FRC #0097
It is built mostly from FIRST parts, and with very little interference from the MIT contingent of the team. It uses the standard KOP Victor 884s. 120 Hz is fast enough. I thought I read somewhere that the commerical Segway controller checks its sensors at 100 Hz? The bigger problem with the 884s is the neutral deadband, but we have a software fix for that.
We just posted a big folder of more detailed technical documentation, which I'm sure you'll all appreciate much more than the general public, having knowledge of the components:
http://web.mit.edu/first/segway/segspecs.zip (13MB!)
Unread 24-08-2007, 00:40
Heavy Metal's Avatar
Heavy Metal Heavy Metal is offline
a world without music is true chaos
AKA: Nate
Heavy Metal is an unknown quantity at this point
awesome pretty good
i dont think its fair to point out theres looks like a stripped version of segway
they built something top-notch engineers build and upgrade
its pretty for just MIT
My favorite online game http://runescape.com/
warning: vex may cause...
1.sleepless nights
2.anger issues
3.the possbility to go insane
plz build responsibly
(ironically webster defines vex as:
1.to bring trouble, distress, or agitation to
(this suggests stress and/or anger after hours of building vex)
Unread 25-08-2007, 15:48
-q
I think it's very doable, as far as power needs are concerned I don't think they should be much more than your average FIRST robot, especially considering that most people don't ram into things or push on a Segway. (Albeit Segways need to go faster, and probably weigh ~40-50 lbs more too... assuming we are dealing with lightweight nerds like myself)
120hz is actually a relatively fast rate for this type of application, a few kilohertz seems like overkill, even for the REAL Segway
Build two and tell your boss he gets to keep one!
Team 701
Unread 26-08-2007, 21:41
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
Looks great, you should be proud of what you have acomplished. Now that you have a base idea that works to build from you can do almost anything with it. I bet it cost you alot less than the real thing. Keep building.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
DIY open exhaust Mike Chit-Chat 3 06-06-2007 22:57
DIY auto gauges for your computer!! John Gutmann Chit-Chat 1 02-06-2007 12:50
DIY water cooling Morenoh149 Chit-Chat 2 28-02-2006 23:44
DIY Active Noise Cancellation phrontist Technical Discussion 20 28-08-2004 07:45
Robot Rivals on the DIY network sanddrag Televised Robotics 1 07-11-2003 22:49
