Break-Even Point to Cost/Revenue problem
Anyone has any suggestion on solving this problem for x?
It's a break even point to a cost and revenue problem. 5.5 sqrt(x) + 10000 = 3.29x where x>o thanks |
Re: Break-Even Point to Cost/Revenue problem
put everything on the right side of the equation and treat it as a quadratic. If it helps you come to grips with it better, make yourself a dummy variable "a". Let a=sqrt(x). So a^2 = x. And then it's a straight forward quadratic.
thanks for the suggestion kevin. very clever, but it didnt work. i ended up w/ x~54.3.
the proposed solution is x~3133. |
I refuse to be wrong on my birthday. Also, I ran the numbers and got a = sqrt(x) = 55.63. So x = 3095.6. Mostly, you forgot that that quadratic solves for sqrt(x) so you need to square the answer to actually get x.
YOU'RE THE MAN KEVIN, that's it!!!!many thanks....happy birthday! |
| spring break | thatphotochick | Chit-Chat | 6 | 29-03-2006 17:41 |
| Before I break anything... | Dmitri | Motors | 7 | 10-02-2004 20:36 |
| Even even more Segway stuff. | FotoPlasma | Dean Kamen's Inventions | 1 | 15-08-2003 22:15 |
| Taking A Well-Deserved Break... | archiver | 2000 | 0 | 23-06-2002 22:04 |
