Go to Post Life is totally random and there's nothing you can do to change that. - kristen [more]
Go Back   Chief Delphi > Other > VEX
Unread 13-09-2007, 13:25
ManicMechanic ManicMechanic is offline
AKA: Yolande
VRC #0438 (Metal Gear)
ManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond reputeManicMechanic has a reputation beyond repute
Reusing Lock Nuts
Has anyone successfully reused nylock nuts and tested them in battle? When you unscrew and reuse, they appear to be tight the second time around, but I'd hate to see them disintegrate on the field. While the relative economics of entering a bot in the competition might say "throw them away", I've always had an aversion to needless waste.
The team has finally consented to disassemble last year's bot & summer projects, in preparation for THE GAME (lose!).
He is no fool who gives what he cannot keep to gain that which he cannot lose. - Jim Elliot
Unread 13-09-2007, 14:26
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Re: Reusing Lock Nuts
Idk but from what I've learned about locknuts they can really only be used one time. Yeah they screw in tight the second or third time around but the more you re-use them the more the thread eats away at the nylon washer making it a bit easier for it to be unscrewed on it own. Personally its not useless waste. The reason for the lock nut / or even using locktite is so that you use it on something YOU DO NOT intend on taking apart (at least often anyway). We use them at my job to hold a touchscreen in place on vending equip. The purpose is so that if the train goes by it doesn't rattle the touchscreen loose to the point where it can fall and break. But everyonce and awhile we need to replace the touchscreen and half to undo the lock nuts to get the module off and those same lock nuts usually don't have the same tightness to them once un-done. But since there are so many holding it in place we don't usually worry about one failing.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
reusing drive design VEN General Forum 20 04-04-2006 03:35
80/20 t-bolts/nuts? Henry Anthony Inventor 6 16-02-2006 07:13
Reusing gearbox & bearings BlacKnight6604 Technical Discussion 2 14-01-2004 21:49
Reusing Old Gyros Venkatesh Programming 4 14-01-2004 09:44
Reusing Parts Sachiel7 Technical Discussion 4 18-10-2003 10:51
